air compressor?
wangdango
My old Sears 1 hp compressor has finally died, (at least 30 yrs old). I would like to buy a replacement and wondered who has purchased what. I do not need a big HP or volume compressor and the 1 hp has worked for me. I realize some are very expensive and some are cheap, and you "get what you pay for." That being said, I would not be against a Craigslist purchase of a used one like I had. Opinions everyone?
THanks
Ed
TR3driver
Great Pumpkin - R.I.P
In what way did your old one die? If the tank is still sound, it might be worth repairing rather than replacing. If the motor hums and then kicks out the breaker or thermal cutout, the repair might be as simple as cleaning the start switch contacts inside the motor or replacing the starting capacitor.
Sears offers compressors from several different sources (or at least used to). Mine just says "Craftsman", but I'm fairly certain was actually made by Ingersoll-Rand. I bought it well used (already over 20 years old) and it's still going strong after another 15 years or so. I wouldn't hesitate to buy another one like it (tho again, I'd be more likely to repair the one I have as long as the tank is sound).
dklawson
As Randall said, since you were happy with your old compressor you may want to dig into it and see what failed.
I have an older Craftsman, 2-cylinder, 2-HP, portable, horizontal tank unit. I've had it 28 years and I bought it used. It has required service twice during the time I owned it. In both cases the reed valves in the head assembly failed. Nothing lasts forever. The parts are still available so each time I have cleaned up the heads, fit new valves, and kept using the same compressor.
TomMull
I think there are at least 4 variables: 1. Physical size, they do take up space, 2. Capacity, how much air (CFM) do you need, 3. Noise level and 4. Portability.
Perhaps you can narrow your choices a bit.
Tom
Rob Glasgow
I purchased one from Harbor Freight a while back and returned it because it was so noisy when running. had to pay a restockng fee but I just couldn't stand the noise. I bought a used Sears unit on craigslist that was a piston unit and am quite happy with it.
dklawson
Any diaphragm type compressor is going to be loud... HF or not. If you can find them, two cylinder cast iron piston pumps are generally quieter and longer lasting. Used (like your Sears unit and mine) can be really good buys depending on how much use they have seen.
TR3driver
Even the piston units get annoying to me; so I put the compressor out in the back yard and ran a pipe to the garage. As an added bonus, the long run of 3/4 iron pipe also helps dry the air considerably.
Original plan was to have a (wired) remote control from the garage that would both apply power to the compressor and open the ball valve. I got as far as installing the contactor to control the compressor, but still haven't run the control circuit.
Just a thought.
TomMull
Just a thought.
Outside is great idea but here in the Northeast I need to build a shed. Plan to do that. Tom
Jim_Stevens
I found a Saylor Beall 735 on CL and love it. 80-gal, 3-hp, 220v. It's a bohemoth. All parts are available.
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
TomMull Scroll Air Compressor Restoration & Tools 13
S TR2/3/3A Air compressor crud Triumph 7
Jim_Stevens Off Topic Saylor-Beall air compressor on ebay Triumph 3
G Portable 12V DC Air Compressor Austin Healey 6
TomMull Air compressor help needed Restoration & Tools 2
KVH Air Compressor Restoration & Tools 2
TomMull Air Compressor Solution? Restoration & Tools 8
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
M Air Compressor Noise Spridgets 16
M Sandblaster/air compressor Spridgets 22
T Air compressor min CFM for media blasting Triumph 14
Jim_Gruber Air Compressor Motor has crapped out-thoughts Spridgets 19
Lin air compressor Austin Healey 12
J air compressor H2O problem Restoration & Tools 9
Tinkerman Air Compressor Help Triumph 22
jlaird Progress, air compressor Spridgets 7
bash Air compressor advice, please Restoration & Tools 18
sparkydave Air compressor maintenance Restoration & Tools 3
Y Air Compressor Recomendation Austin Healey 13
N Good Deal on Shop Air Compressor Restoration & Tools 9
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
