TR2/3/3A 7.68, outer tie rod
Dr_Mike
Seven and two thirds seems a very odd measurement to appear in a car manual, yet there it is. Does any one know where it came from, or is/was it just the actual measurement when the tracking was correct?
Without the recommend ballast ( 300 lbs., equivalent to one very fat person or two skinny, malnourished Brits) my car seems to toe out. Can be adjusted. Any ideas comments?
TR3driver
Great Pumpkin - R.I.P
That's my guess. Furthermore, someone measured it as 19.5 cm, then converted to inches for the manual.
The actual toe angle is much more important, and the resulting tie rod length dependent on so many manufacturing variables, that there is no earthly reason to give a measurement to .01 inches. +/- .5 cm is more reasonable.
TRMark
Bronze
Britain didn't go metric until 1965, oh and 300 lb is 21.4 stone. Not that any of this means anything. I agree with Randall, actual is more important. You can use the string method and set the toe in your garage, it is not difficult just time consuming to set up. I don't know what wheels you have, but I have to wonder at the accuracy of measuring off of ancient wheels. I read (probably here) the factory spec for run out was .10", so you could be off by almost a quarter of an inch just because. Oops, just noticed you live in Canada, sorry about the imperial measurement, I can do metric but it is a second language to me.
Geo Hahn
Britain didn't go metric until 1965...
And yet the commission plate in a TR3A gives the weight in kilos.
I do not think it was a clean implementation (like, say, Sweden driving on the right). Even to this day asking a Brit for directions he is likely to give it to you in miles.
sp53
I believe the 7 and roughly 5/8 is to give an approximation so that when someone is setting up a front end they are able to get very close to the correct toe. That way one side will not be 8 inches and the side 6 and something inches. I had a car where the front end was done way out of balance with the tie rods. I do not think it matters too much unless the one side is extended so much more the threads are about runout and that would be weaker; I would think.
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
ChrisS Steering Rack Outer Tie Rod End Size Spridgets 3
tr6web TR6 Outer tie rod question - TR6 Triumph 5
Cain Lubing Outer Tie-Rod Joint/Upper Ball Joint Triumph 5
B TR4/4A Outer tie rods Triumph 8
tr6web TR6 Outer tie rods - TR6 Triumph 10
SNClocks Gap between inner and outer fenders Spridgets 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
69MGC MGC Replacing an Outer Wheel Well panel MG 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
red57 What is correct wire harness outer wrap Austin Healey 17
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
Lukens Outer rocker showing "rust" Restoration & Tools 11
B Outer steering column connection to the steering box Austin Healey 6
H General Tech Door Glass outer seals installation Triumph 6
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
F TR4/4A TR4 inner and outer sills Triumph 2
MisterB Outer structure repair order/checklist Austin Healey 9
S TR2/3/3A outer sill and fan tail Triumph 11
red57 Outer Sill/Rocker fit problem Austin Healey 11
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
M BT7 Outer Sill Replacement Austin Healey 2
H TR4/4A Outer door waist seal Triumph 5
britlover TR4/4A Anyone know a source for TR4-6 outer sills that actually fit? Triumph 13
S inner sills, outer sills, a post...where to start? Spridgets 28
I Sealing new outer panels on BN1 Austin Healey 10
O TR6 Outer Rockers WTB Restoration & Tools 0
O TR6 TR6 Outer Rocker Panels WTB Triumph 0
G OD of inner spring is tight to ID of outer spring Triumph 3
G excess wear on outer edge of front tires Austin Healey 13
M Photos of my outer sill repair Spridgets 11
M TR2/3/3A TR3 outer sill replacement Triumph 15
Jim_Gruber Looking for DS Outer Rocker - Front 4" Spridgets 9
hondo402000 TR6 TR6 outer sill replacement Triumph 2
germanmichel Fixing outer tube in steering box Austin Healey 11
K TR2/3/3A Paging TR3Driver re: trunnion outer washers... Triumph 4
J TR6 joining the inner and outer sills on a TR6? Triumph 1
G TR2/3/3A TR3 lower outer trunnion Triumph 4
M Outer Wheel Bearing - interference fit v Quality? Triumph 2
J TR6 Replacing TR6 Outer Rocker Panels Help Triumph 1
G Plan 9 from Outer Space Triumph 3
C How does one remove the outer door chrome? Austin Healey 2
A Outer sill replacement Triumph 2
