TR2/3/3A 1/4 mile fast time driving technique
TFB
I haven't tried to time my basically stock TR3 for off the line performance but I am curious about best technique,particurally how a factory test driver would get the best time,usually reported around 18 seconds for a 1/4 mile.
What would be the ideal rpm shift points etc.,
Thanks
Tom
Geo Hahn
I would suppose with an unmodified engine you would shift at redline unless you had reason to believe that you could safely go higher (or didn't much care which is possibly how a factory driver would treat the car).
glemon
Dump the clutch from about 3000 rpm to start, and shift at the redline full throttle as quickly as possible. I had a chance to do quarter mile times in my TR250 a couple years ago and was able to get pretty consistent times (don't know if they were best possible, but they were consistent!)
TomMull
Putting a stock TR3 on the dragstrip reminds me of the time a farmer I once knew hitched up a pair of milking cows for the ox pulling contest at the town Fair.
Tom
CJD
Tom
Yep...shift whenever you like, cause the Prius you're racing is going to win unless his battery goes flat.
T
TFB
Thanks for the responses and humor.I have no intention of drag racing,but the factory obviously tested the cars in the 1/4 mile drag format.
I actually think that winding up to redline in all gears is not the fastest,but was curious what expertise might be out there.
Thanks
tom
HealeyRick
If you look at the graph and charts from this Sports Car Illustrated article it seems they shifted at the red line in 1st and 2nd and stayed in 3rd until they finished the 1/4. They cut .6 sec off their 0-60 time by shifting from 2nd to 2nd overdrive instead of making the 2-3 shift. They probably played around with different launch rpms to see what gave them the best times: https://drive.google.com/file/d/0B5xnnKbPEWx5Z2h5V2JiTmF2Wkk/edit
T
TFB
Thanks Rick.That is just the kind of of info I was curious about.Lots of good stuff in the article,thanks again
Tom
glemon
Why flog a 50 year old motor?
A. It is fun
B. It is kind of what they were made for
C. Triumph TR 4 Cylinders are pretty tough old beasts, I flogged the **** out of my 4A as only a 20 year old can and never broke anything in the motor (of course it was only about 15 years old then)
Darrell_Walker
Me, too. Though I did break the front suspension mount (but it was previously broken anyway).
glemon
Me too, front suspension mount, actually popped as I carefully was backing up to parallel park, hit the brakes and it snapped. Am am sure prior abuse and metal fatigue had nothing to do with it.....
Simon TR4a
I would imagine you want to keep the engine between peak torque and peak horsepower rpm. But going a bit past the peak to redline would give the benefit of lower gearing for a better multiplier effect, which would more than compensate for a small drop in power past the peak. I found in racing that it is possible to change gears with only a dip of the clutch, not fully disengaging as you would do in normal driving. This would reduce the brief time interval when the engine is not driving the car forward.
A close ratio second would be a really big help, but that's another matter!
CJD
Take out the clutch spring for a few more milliseconds on the shift...or adjust the linkage to 0 play.
HealeyRick
Now we're getting into the area of shaving tenths, aka "destructive testing", aka "It's not my car, what the ****?" Tach up the motor and "sidestep the clutch" (allowing your left foot to slide off the side of the clutch pedal and let the clutch lever bang up to the top for immediate clutch engagement. Preload the shift lever for the 1-2 shift and when you're near the shift point, dab the clutch and yank the lever back into 2nd, then to 3rd, etc. This is literally known as "banging gears." (aka speed shifting).Sometimes these shifts are made without dipping the clutch. Disclaimer: My familiarity with these procedures should in no way be considered an acknowledgement of unsanctioned contests of speed. :angel:
T Thoughts on surviving a 600 mile fast road rally Triumph 17
tr6nitjulius TR6 Got that 395,000 mile feeling Triumph 2
D TR2/3/3A TR2 Flying Mile question Triumph 11
Nugget Texas 200 mile road trip success Spridgets 13
Guido36 9k-Mile BN2 at Auction Austin Healey 13
dougie Lowest Mile Works Sebring Sprite for Sale Austin Healey 5
P For Sale 38k Mile 1993 Bentley Turbo R For Sale on Bring a Trailer Other British Classifieds 0
drooartz 400 mile road trip in the 4-door Spridget Spridgets 11
P TR6 Won't start after 10-mile run Triumph 21
PAUL161 T-Series First 60 Mile Drive MG 1
HealeyRick 39,000 Mile BN1 Austin Healey 0
B TR6 Low mile tr6 Triumph 12
cbrvfr Getting ready for a 1200 mile trip in the BN4 Austin Healey 26
rlich8 TR6 '76 TR6 - De-Smog or Leave? 19k original mile car Triumph 29
Pythias Ready for the 4500 mile trip. Spridgets 2
glemon Wedge Low Mile Wedge Triumph 7
drooartz 1000 mile report Spridgets 15
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
B 2000 mile journey ahead MG 5
3798j 1/4 mile Land Rover Other British Cars 20
M 99,999 just one more mile!! Triumph 7
BobbyD 150 Mile Drive Triumph 3
Brosky 35 mile shake down cruise Triumph 20
D 116 mile maiden voyage, no real complaints, but... MG 4
G TR6 My 1600 mile weekend drive for Ebay TR6. Triumph 12
kcbugeye1275 150 mile trip Spridgets 8
bighly Nelson photos [A picture perfect 4,700 mile run] Austin Healey 4
B Yosemite 500 mile trip Austin Healey 4
Alan_Myers Synth. oils in old TRs... 6000 mile break-in? Triumph 5
J 36K mile Lotus Eclat as a daily driver? What do U Lotus 2
S TR2/3/3A TR3 speedometer and wheel revs per mile Triumph 6
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
P Fast Healey at Lime Rock. Austin Healey 2
wkilleffer MGB Air leaks and fast idle speed MG 11
HealeyPassion AH Spares Fast Flow Manifold.... Austin Healey 32
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
DerekJ Indicator blinking too fast Austin Healey 13
D Piper Fast Road Cam Installation Austin Healey 9
D Fast Road Cam Austin Healey 2
B Fast Idle Spridgets 7
steveg Fast and the Furious on Friday Oct 25 Austin Healey 2
