Fast Road Cam
dmorris1
Member
I have a 1967 BJ8 that has a rebuilt motor, with a fast road cam installed. Does anyone know what the degrees of advance should be for this cam at different RPMs? What is the range from high to low?
Keoke
I think you will get a response if you specify the model number and manufacturer of your cam.
OTOH,perhaps the engine rebuilder can give you that information.
EV2239
Failing that I'd try standard BJ8 timing and see how it goes.
Generally speaking, if fast cams need more advance as the hotter ones do, it's at tickover and up to say 2000 rpm and from then on they want the same as standard camshafts. For this reason tuners often restrict the total advance the distributor is capable of by modifying the centrifugal advance assembly.
D Piper Fast Road Cam Installation Austin Healey 9
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
K TR2/3/3A TR3 Fast Road Cam and "RL" SU needles Triumph 4
K TR2/3/3A Valve gaps...fast road cam...TR3 Triumph 6
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
T Thoughts on surviving a 600 mile fast road rally Triumph 17
D Advice: Moss fast road suspension kit MG 1
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
P Fast Healey at Lime Rock. Austin Healey 2
wkilleffer MGB Air leaks and fast idle speed MG 11
HealeyPassion AH Spares Fast Flow Manifold.... Austin Healey 32
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
DerekJ Indicator blinking too fast Austin Healey 13
B Fast Idle Spridgets 7
steveg Fast and the Furious on Friday Oct 25 Austin Healey 2
glemon Better Move Fast Spridgets 4
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
KVH Idle Too Fast Triumph 36
drambuie Old British car film..... The Fast and Furious 1955 full movie Austin Healey 17
L Fast idle? British Motor Corp 4
StagByTriumph GT6 1968 GT6 for sale in Colorado Auto Parts Salvage - act fast Triumph 8
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
lbc_newbie MGA Someone needs to get this, fast... MGA $1500 in SC MG 4
HerronScott OT: Honest officer, I wasn't going that fast... Triumph 8
C An MG in fast company... Racing 0
HealeyRick The Fast and the Furious XK 120 Jaguar 2
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
MadMarx [video] Zandvoort - fast qualy lap Triumph 11
PAUL161 Stirling Moss in one fast MG! 1957 Bonneville! MG 7
B Tired of fast food style restorations? Restoration & Tools 7
T Post-War Other How says a Herald isn't fast Triumph 19
C REALLY fast British race car [circa 1971] Racing 0
Jer First Drive of 2010 Season is Fast Approaching... Spridgets 11
T APT Fast - great experience Triumph 3
P TR6 76 TR6 fast idel problem Triumph 5
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
X Weber 32/36 DGV fast idle rod MG 0
NardisCNC How fast can you pull your Midget engine / trans?? Spridgets 17
jdubois TR2/3/3A TR3A fast idle cam connection? Triumph 26
T TR6 How fast can a TR6 go? Triumph 51
aeronca65t Fast British Car Other British Cars 5
