TR2/3/3A Electric Fuel Pump Sound
mastaphixa
Bronze
I am working on my friends TR3. He had one back in the day with an electric fuel pump. He says when he would start the car, he'd turn the fuel pump on and hear it go ticky, ticky, tick and then stop. He would then hit the starter. He wants a fuel pump like that installed on the car he owns now. I know this is a really strange question, but which of the currently offered electric pumps would be described as making a noise like that?
Got_All_4
Interesting that he said he turned it on. Must have been a direct electric hook up with a switch. Not a very safe set up if that's the case. I had a electric fuel pump set up in my TR250 that turned on with the ignition switch was in the on position. Worked great but if the car stalls the pump keeps pumping (happened to my daughter driving it and a 10' puddle of fuel under the car), an accident where driver is impaired and can't turn the ignition off. So I installed a oil pressure switch. No oil pressure the pump is off. Worked great put if the car sits for a while and the gas evaporates out of the float chambers the car doesn't start with out a bunch of priming and battery charging. I went back to a mechanical fuel pump. The ticking is cute but let a Triumph be a Triumph.
I'll try to dig out my pump and post a pic of it. It also ticked while running. My Triumph mechanic told me about it that he used it in MGs. Purchased it from my local Car Quest too for less the $20. Ironically it looks a lot like the one in another recent post for a back up electric pump. I did buy one as a back up for my TR6.
Sarastro
There are a couple kinds of pumps. The rotary type are quiet, but there are others, which work like the mechanical ones, but are electrically operated. You want one of the latter. There is a pump by Facet, now part of Purolator, which works that way. It's very reliable and can be obtained with various output pressures. For an example of the installation in my Porsche, see https://www.nonlintec.com/porsche/fuel/.
Some sort of mechanism that turns the pump off in an accident is not a bad idea. Some people use the oil-pressure switch, but with a circuit that turns it on long enough to start the car. I have an inertial switch. I will do the same in my TR4A when I get it to that point.
Gliderman8
I currently use a relay to my Facet fuel pump. It senses distributor rotation and energizes the pump only when the distributor is turning. If the engine stalls due to an accident power to the fuel pump is cut off.
TR3driver
Great Pumpkin - R.I.P
Maybe others work different, but the Facet pumps I have will keep on clicking even after the fuel pressure has come up. They don't stop like the SU pumps do.
Sarastro
Mine is pretty loud until the float bowls fill up. Then, it does give off a muffled click, but it's quiet enough to be drowned out by the Porsche's engine noise (which, I guess, isn't saying much). Of course, there are a couple models of the Facet pump. I've used only the little cubes; can't say much about the others.
Got_All_4
As promised. The pump in the middle is the one that ticks. The bottom one is the same as the middle one but I never ran it. There is a link for it on Ebay in another active post for an emergency fuel pump.
AndreL TR6 Conversion to electric fuel pump Triumph 8
Martinld123 Electric Fuel Pump Austin Healey 6
R Electric fuel pump wiring Spridgets 4
B TR4/4A Mechanical fuel pump vs electric Triumph 16
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
johnrip Wedge tr7 electric fuel pump Triumph 2
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
T ?Changing BE to SU electric fuel pump Spridgets 8
T TR2/3/3A Location for electric fuel pump? Triumph 21
tinman58 TR2/3/3A Electric fuel pump questions. Triumph 5
Coyote1 General Tech Is there a quiet electric fuel pump Triumph 11
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
Gliderman8 More electric fuel pump questions... Triumph 6
Gliderman8 Electric fuel pump install help... please Triumph 24
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
bigjones Installing electric fuel pump Spridgets 34
M electric fuel pump power supply? Triumph 14
tban52 Electric fuel pump Triumph 5
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
jaegzie hooking up electric fuel pump Spridgets 7
veale001 Mechanical or Electric Fuel pump? Triumph 15
drooartz Running fuel lines/electric pump Spridgets 20
M_Pied_Lourd Old Electric Fuel Pump Question Triumph 15
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
sparkydave Electric fuel pump question Spridgets 13
T Electric fuel pump question Triumph 29
emann Electric Fuel Pump Spridgets 6
bluemiata90 electric fuel pump....rear or engine compartment Triumph 7
J Power for electric fuel pump Spridgets 4
B BE Electric Fuel Pump Q Spridgets 22
D TR4/4A Electric Fuel Pump for TR4 Triumph 5
P Electric Fuel Pump for Bugeye??? Spridgets 12
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
B Electric fuel pump for a bugeye - Questions. Spridgets 13
roofman Facet electric fuel pump - need advice Triumph 15
hondo402000 electric fuel pump installation Triumph 5
P TR4/4A TR4A Electric Fuel Pump Installation Triumph 7
K more electric fuel pump ?s MG 8
T Electric vs Mechanical fuel pump? Triumph 3
T AC Electric fuel pumps - time for some schooling.. Triumph 10
L Electric fuel pumps Lotus 10
J electric fuel pumps Austin Healey 9
Guido36 Electric Power Steering Austin Healey 2
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
