TR2/3/3A H6 Throttle Linkage
ckeithjordan
As I'm having my carburetors rebuilt by Joe Curto, I want to make sure everything around them is in fine working condition. The original linkage feels a bit "sloppy," it may well be the pivot/bellcrank on the manifold is worn. It feels like the forward part of the linkage binds or hits the manifold as a result, so I've purchased a very nice replacement throttle linkage from Britsport (they sell them on eBay). It's so nice, new and shiny, it qualifies as under the bonnet bling...
My question is this: There are four threaded ball joints on the linkage. They feel "tight," you can adjust them to loosen them up. How loose or tight should they be? Move freely or with some friction? Also, I imagine they should be lubricated, if so, with what?
TR3driver
Great Pumpkin - R.I.P
A small amount of friction is OK. The book calls for an occasional drop of oil; but with the original type that can be disassembled, I start out packing them with grease. (I don't know if Britsport sells original type, or the more modern ones that can't be disassembled. Used to be you could buy those pivots from a semi truck dealer, but I haven't shopped for them in many years.)
Geo Hahn
An aside - I know a TR3 owner whom I have watched as he checked his oil. His routine was to pull the dipstick as usual but before he wipes and reinserts it he touches the end to each of those pivots.
I just use an oil can but his method had a certain elegant quality to it (elegant as dirty oil can be).
sp53
Those balls get egg shaped over time, so if you do have new ones, nice. Plus Joe would be a good guy to ask about those ball joints. I have been collecting them for a while off eBay and parts cars. They used to sell something similar at parts stores, but they were a little bigger. For oil, I am using that Teflon stuff because oil will gather dirt and small chunks of sand.
The return on H6 carburetors has always been a problem for me. Don, E. who bought his tr3 new said he has always had an idle return the problem as well and pull the linkage back with his foot. I still do that sometimes and have fought it for 45 years. My experience has been a good distributor helps the idle come back.
ckeithjordan
ckeithjordan
Attached is a photo of the Britsport linkage. I think it's is very well-made. The also make the pivot set-up only, but the difference in price makes it worthwhile to get the whole linkage.
I took my old one off, then matched the new one to length by adjusting the outer linkage housings. I took them apart and lubricated with grease around the ball joints inside (there's a spring and two cups, one is adjustable by screwing down to maintain slight pressure on the ball). I intend to install it in the next day or so. I also checked the pedal return, which is obviously freer without the linkage attached, but I think this will help. I don't want to take the pedal apart at the moment. I'm hoping the combination of new linkage and rebuilt carbs (and the distributor, which is on it's way to Jeff Schlemmer) will do the trick.
https://www.ebay.com/itm/TRIUMPH-TR...ash=item41d7cbca7f:g:I7wAAOSwU-pXuPdo&vxp=mtr
Geo Hahn
Those balls get egg shaped over time...
One of mine did this and was popping apart at the most inconvenient times. As a temporary fix I took it apart and added a washer which changed the orientation of the tightened fitting by 90°. That 'temporary fix' was about 10 or 12 years ago - you know how it is once a problem stops being a problem.
TexasKnucklehead
That 'temporary fix' was about 10 or 12 years ago.
Maybe in a couple years you can turn it 45 degrees to get a few more decades out it.
I have a "round-tuit" for those type of fixes, but I can never find it.
Somehow these cars are a combination of "if it works don't fix it" and "as long as you're in there...".
CJD
On the TR2 I welded the balls back up and ground them round again. Should be good for another 60 years?!? Of course that was after I bought new ones...that turned out to look entirely non-original from one of the big three.
sp53
That looks like a nice quality original set; I like it, and it is from Seattle. Time will tell how long they last; I am not sure how hard the steel balls should be, but my guess is a hardened material. I would tighten the ball spring combo tight enough so they do not come out and lose enough for free movement.
I had a 4 wheeler buddy of mine show me how a cotter key is finish out. They do not fold out --one on each side; they fold over the face. One leg is cut short and bent back and the other leg is left long and folded over the face of the nut and not over the flats, just a little detail. Look for a stock front wheel bearing picture.
If it is not too confidential, I am curious how much is Joe charging for complete rebuilds these days?
John I think Moss a special fine for most guys like us. I send half of it back.
ckeithjordan
ckeithjordan
From the eBay description: “The bellcrank pivot plate and lever are machined from mild steel, the pivot pin and socket are made from hardened 4130 Chrome Moly, then silver soldered together, not brazed as original.”
I installed it yesterday and it went in fine and looks good, too. I lubricated the pivot joints with grease. We’ll see how everything works when the carbs come back.
Mr. Curto is charging $525 to rebuild an H6 pair, a bargain for someone like me, who is SU-challenged.
DavidApp
Getting ready to send him my carbs.
I cleaned them up then replaced the needles, jets and all the seals then realized the butterfly bushes are worn. From what I have read doing the bushes takes more than a drill press. I gather he gets them setup as well as a complete rebuild. Been told they come back like new.
David
TR3driver
Yeah, you've got to have the right kind of drill, too.
DavidApp
And in line reamer. I think he sells the reamers but it is almost cheaper to get your carbs. done than buy the reamer.
David
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 28
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
MY66AH Throttle Linkage Spridgets 9
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
newmexTR3 TR2/3/3A TR3 Throttle linkage pics needed Triumph 19
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
A TR4/4A TR4A Throttle - Lower linkage length Triumph 1
vette Throttle Linkage Ball Joints Austin Healey 5
T Keeping the throttle linkage shiny Triumph 5
DrEntropy Alfa throttle linkage? Other Cars 3
MrBlueSky Wedge tr8 edelbrock throttle linkage Triumph 2
R GT6 Need to see GT6 Mk1 Throttle linkage Triumph 9
drooartz Throttle linkage question Spridgets 6
Zimmycobra Throttle linkage saga continues Triumph 5
Zimmycobra TR4/4A TR4A throttle linkage Triumph 6
Got_All_4 TR5/TR250 TR250 throttle linkage problem Triumph 6
T TR2/3/3A TR3 Throttle linkage return spring Triumph 3
D Ratco Throttle Linkage Triumph 8
J Healey 3000 - throttle linkage [cable] Austin Healey 11
T TR6 Picture/diagram of TR6 throttle linkage Triumph 7
bighly Improved throttle linkage MG 1
philman Wedge TR8 Throttle Cable linkage help Triumph 3
G Throttle switch and linkage Austin Healey 5
T Throttle linkage question Triumph 2
chicken Throttle linkage for BJ7 Austin Healey 6
B BJ7 Throttle Linkage Problem - Access? Austin Healey 6
D Ratco Throttle Linkage Triumph 31
vping Throttle linkage - I need a pic MG 13
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
S HS2 SU dual carb throttle/choke linkage Spridgets 10
tosoutherncars DGV throttle linkage help needed Spridgets 4
X Throttle linkage sticking Spridgets 6
DrEntropy YO! Brosky!!! [RE: Throttle linkage couplings] Triumph 15
Brosky Throttle linkage from Ratco Triumph 35
P Throttle linkage on 1967 LHD. BJ8 Austin Healey 5
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
G Triple Stromberg throttle linkage Triumph 12
S Adjusting Throttle Linkage Austin Healey 3
mbrooks BN2 throttle linkage Austin Healey 1
Lin Carb Linkage and Throttle Cable Austin Healey 3
