Results 1 to 8 of 8
Thread: Front Hub Inner Bearing Seal
Forum to discuss Austin Healey Sports Cars
  1. #1
    Jedi Trainee aero3113's Avatar
    Join Date
    Nov 2016
    Location
    Setauket NY (Long Island)
    Posts
    213
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Does anyone have a good part number for the inner Bearing Seal on the front hubs? From what I understand the same Seal is used on all models. Thanks!
  2. #2
    Join Date
    Nov 2016
    Location
    Posts
    213
    Thanks Thanks Given
    Thanked in
    Re: Front Hub Inner Bearing Seal
    I see the 535-055 part number on Moss but I can't find it outside of Moss. Is there a different number to cross reference?
  3. #3
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,581
    Thanks Thanks Given
    1
    32
    Thanked in
    Here's a screenshot from a spreadsheet provided by a Healey owner (Steve?):
  4. #4
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,500
    Thanks Thanks Given
    11
    19
    Thanked in
    Here's a little trick I use. Go to http://lbcarco.com.They have a part search function. If you put in a Moss part # it will also give you the original BMC part # which can be handy in searching other sites not using Moss #s. It works in reverse, too. If you have a BMC parts manual, you can plug the original part # in the search function and get the Moss #. Quite handy as I've found parts using the original number that don't show up in the Moss Healey catalog. The BMC # for the seal is GHS 103. I found a Rock Auto listing for the front seal here: http://www.rockauto.com/en/catalog/a...heel+seal,1860 It's a Centric and I have no experience with their stuff so can't tell about quality. While we're in the neighborhood of the wheel bearings, a lot of the old reliable bearings like some Timkens are no longer manufactured in the US. It might be worth checking for some NOS parts made in the US before buying some of the offshore stuff.
    Rick
  5. #5
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,133
    Thanks Thanks Given
    44
    55
    Thanked in
    I just read the NKK seal from one of my old BN6 front hubs:
    2.062" 2.875" .375"
    By observation, this is ID, OD and width of section
    You should be able to buy this seal widely.
    Not sure why you wouldn't want to buy it from Moss.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  6. #6
    Join Date
    Nov 2016
    Location
    Posts
    213
    Thanks Thanks Given
    Thanked in
    Thanks for the info guys!
    I just got these numbers off my bearings?
    Outer - 4T-07087X
    Inner - LM67048
    Steveg, I just like to price around.
  7. #7
    Join Date
    Oct 2013
    Location
    Louisville, Kentucky
    Posts
    96
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I can assure you that the SKF 19264 seal has too small of an OD measurement to fit a BJ8 front hub; I have the skf seal and a new hub in front of me as I am posting this reply.
    Hope this helps,
    John
  8. #8
    Join Date
    Nov 2016
    Location
    Posts
    213
    Thanks Thanks Given
    Thanked in
    Thanks John, I'll probably end up ordering the seal from Moss.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
