Wheel stud dimensions?
Nader
I broke a rear wheel stud while torquing the lug nuts, so now I need to replace it. Does anyone know offhand what the replacement stud dimensions are? Thanks.
Jim_Gruber
Smaller than you will typically find in the Small Box Auto Parts stores. Take a wheel nut with you.
drooartz
Pretty sure they're 3/8" diameter, can't seem to find the detail anywhere in my notes. Got my last set from Moss I think.
johntennyson
Y'know... if it snapped off when you torqued it down, you might want to think of this as an opportunity to go to larger and stronger studs. I went to 7/16" studs on my Sprite.
Hot Wings
Can you get left hand lug nuts that work with Minilite wheels? I know I'm probably a bit paranoid but I've had a left front wheel depart after getting new tires. I watched the tech use the torque wrench. I've also lost a left rear that I put on, with a known good torque wrench.
One could bore the Minilites to .680" to use American spec alloy nuts but that creates a potential hazard if used with the .625" nuts.
Gerard
... or replace them all. Chances are if one was over torqued, that all were at one time or another.
N
Nader
Yeah, I think I'll be replacing them all. It's easy to forget how small these wheel studs are when you've got full-size enclosed lug nuts that hide those puny studs. 60 ft/lbs later, I've got a busted stud and several more that are overstretched. I'm just waiting to see if the new wheels I ordered are going to need longer studs before I start ordering parts. In the meantime, I'll keep reminding myself that Renault made do with 3 studs/wheel studs on a lot of their cars.
Jim_Gruber
Put that Air Gun away and get out your ratchet. I use a ratcheting breaker bar with a swivel that I keep in Bugsy all the time. When nut is loose I can rotate 90 degrees and spin on the nut quickly and then ratchet to tighten. I've broken my share of studs in the past. Knock on wood won't happen in the future.
N
Nader
If I upgrade to 7/16 studs, what would be involved? I'm assuming the hubs will have to be redrilled, right? Can it be done by hand or drill press, or will I have to take the hubs to a machinist?
Rut
I would take the 4 hubs and drums, axles, wheels to a machine shop to make sure it's done correctly.
Rut
George Zeck Wheel Stud Size? Spridgets 10
M_Pied_Lourd TR2/3/3A Wheel Stud Question Triumph 4
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
S Wheel stud length???? Triumph 10
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
boeingpilot TR4/4A TR4A Wheel Stud Removal Triumph 12
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
Monark192 Broken Wheel Stud Removal Spridgets 4
Jim_Gruber Broken Front Wheel Stud Spridgets 16
mrv8q TR6 TR6 Wheel stud Triumph 2
SCguy rear wheel stud Triumph 11
I wheel stud replacement help Triumph 4
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
kodpkd Leather Steering Wheel Cover Austin Healey 3
KVH General Tech Wheel Dollies Triumph 5
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
P 100/6 Front Wheel Alignment Austin Healey 10
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
prb51 BN6 Wheel/Tire Combo Austin Healey 26
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
LAW75 Derrington Steering Wheel Austin Healey 19
C Spitfire rear wheel bearing Triumph 2
