Hey Tom
Any of the machine shops that work on British engines should be able to check all the parts and tolerances for you and advise you as to what you need to buy. I tore down my engine and brought them all the parts in a box. They cleaned them up and told me what I needed (i.e., oversized bearings, connecting rod piston pin bushings, etc.). They will check the crankshaft mains and ensure you don't need an align bore (or is that line bore?). They will check the big end of the rods and verify round and to spec. Or they can resize those big ends and make them new again. I am so surprised at how smooth my engine is, right up to 5K rpm. They did a great job balancing it. Bring them the flywheel and pressure plate so they can balance everything together. Also, don't forget the crank pully or nose piece (if your engine has that). I'd bring them the clunky fan too, if it is the nice aluminum TR3 model. They can balance everything. My total machine shop bill was about $1,600 and they did everything I needed to start assembling. Now those are Sacramento prices, which will be high for many of the other states and probably a bit less than SoCal.
They found a defect in one of my connecting rods and told me to get a new one. I bought two new single rods (two purchases) from Ebay and each weighed in so differently than my original rods, they couldn't make them work. I ended up buying a set of four used rods and changing them all out in order to make it work.
Keep posting questions and progress. Engine building can be a lot of fun.
