TR2/3/3A turn signal repair tr3
TR3Barney
Does any one know if parts are available for the turn signal like the cancelation ring and trip dogs? I know Lucas still makes a complete unit, but cannot find where Lucas offers any parts.
NutmegCT
Barney - The Roadster Factory has the Signal Switch and Horn Push Assembly in their catalog.
TRF item # 201872 or 201872/A
www.the-roadster-factory.com
Customer Service:
(800) 283-3723
9:00 a.m. - 4:30 p.m. EST
Monday - Friday
Technical Assistance:
(814) 446-4491
12:30 p.m. - 6:00 p.m. EST
Monday - Friday
I don't know about individual parts, but give them a call. You talk to a real human (!) who can get you more info.
Tom
Stinger TR4/4A TR4A Turn Signal Housing Repair Triumph 8
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Help 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
A turn signal knocked off center Austin Healey 14
D TR2/3/3A Turn signal cancel? Triumph 11
adcronin For Sale MGB Turn Signal Switches. 62-67 and 68-70 and 70-73 column cover MG Classifieds 0
glemon TR5/TR250 Turn Signal Wont Blink Triumph 1
Brinkerhoff T-Series MG TC turn signal problem MG 1
A TR4/4A Turn signal dash light inop? Triumph 6
B TR2/3/3A Another turn signal problem Triumph 5
Marla TR4/4A Turn signal bulbs Triumph 2
J TR2/3/3A TR3 turn signal issue Triumph 12
R TR2/3/3A Turn signal switch [trafficator] Triumph 2
S Turn Signal Indicator Spridgets 9
B TR2/3/3A Control column turn signal cleaning Triumph 8
Rut TR4/4A Turn signal shaft Triumph 7
G MGB Turn signal, reverse and brake lights MG 9
GTP1960 TR2/3/3A Self canceling turn signal, "hit or miss" Triumph 1
