TR4/4A Turn signal and overdrive switch are reversed
thechileman
I am trying to figure out what the simplest fix is for this problem. My turn signal switch is on the right side of the steering wheel, my overdrive switch is on the left. Everything functions fine, it is just backwards. It appears that the column is installed 180 degrees out. Is there a fix for this that doesn't include removing the column from the car? Any help is appreciated!
Geo Hahn
It's been awhile since I messed with it -- but can't the 2-piece nacelle be installed either way?
If so, the solution may be as simple as rotating it 180° moving the switches and rearranging the wires.
I recall the OD switch has a D shaped mounting hole - but do not recall whether the turn signal switch hole differs. If the holes are the same perhaps the answer is even simpler.
thechileman
thechileman
Hey Geo, I have removed the 2 piece Nacelle, and the problem I see is the "bump" on the inner steering rod that cancels the turn signals is currently on the right side. I was thinking it would need to be on the left side for the indicators to cancel. Is my thinking correct??
Geo Hahn
Wellsir, the good news (I think) is that it all comes apart very easily.
The steering wheel & column are held in place by that clamp (in the engine bay) with the set screw and jam nut. I usually just remove the two bolts that hold the halves of the clamp together, then the whole works (wheel and column) can be pulled out of the car from the drivers seat.
The outer column is held in brackets/clamps (the ones with felt pads) which I think you can loosen to rotate the column.
The column wiring cover (aka Dagger) will need to be loosened as it will need to retain its 6:00 position as the outer column is rotated.
Just visualizing I cannot tell how much else has to be undone to allow the turn signal switch to end up on the other side -- i.e. I cannot tell if the wires from the switch will need to be disconnected and reconnected. If so and depending on where those bullets are, it may be necessary to mess a bit more with the dagger.
Not an onerous task but (as we say in my hiking group) 'make no other afternoon plans'.
thechileman
thechileman
Thanks Geo... Ill take another look at it this week. Sounds doable in an afternoon.
HerronScott
To get the cancellation clip on the right side, I think that in addition to moving the switches to the correct sides (which should be a simple remove and reinstall) that you'll have to at least pull the steering wheel, disconnect the inner column from the upper joint and rotate 180 degrees. That's assuming your turn signal cancellation is working properly today.
Scott
Geo Hahn
... disconnect the inner column from the upper joint and rotate 180 degrees. That's assuming your turn signal cancellation is working properly today...
And here I thought Chris would enjoy driving with the steering wheel upside down.
Yeah, I see you're right -- the clamp only works in one position so the column has to be relocated. Not a big deal but some fiddly bits to be sure are right (ground connections and safety wires).
TRopic6
Aloha c-man,
Look carefully at that turn signal cancellation "bump". It should be a spring-steel clip that snaps onto the column...albeit with some difficulty. Look opposite the 'bump' for a split; you can spring it open and pop it off the column and refit the other way. There should be two 'pips' in the clip that hold it in place. I'm going off memory of my long-ago TR4, but I think the TR6 is the same way. I have one of them somewhere, but would have to dig it out of a box. Also, early TR4s used a turn signal switch with a single canceling 'finger'; later TRs through the 6 use the more common switch with two 'fingers' and a 1-bump clip on the column. Should be no need to pull the wheel unless you want the signal cancellation function and steering wheel to all be centered.
Jeff
59 TR3A & 63 TR4 (in mainland storage):sorrow:
thechileman
thechileman
Thanks for all the suggestions! I will probably start with the simplest, (Tropics suggestion), and work from there. I can't wait to get to it this week!
pdplot
My TR6 signal has stopped cancelling. Works on a left turn once in a great while. I have to remember to self-cancel so I don't become another old geezer driving down the highway with his turn signal on.
Andrew Mace
Just thinking about this and seems to me you can't pull the upper inner column and flip it 180 degrees; the "flat" part at the bottom has to match up with the cutout in the lower column where the adjusting clamp fits. However, it might be easier to pull the upper inner column complete with the wheel in order to flip the canceling clip 180 degrees!
HerronScott
Andy,
I was recommending disconnecting the inner column at the joint because of this (rubber joint) and not the clamp. I don't think you'd have to pull the inner column - just rotate in place and then reattach (but pulling the steering wheel and reattaching so it's not upside down).
Jeff's suggestion on removing the clip and reinstalling on the other side might be easier though.
Scott
Foura
I don't think you can just flip the column. The two switches are different. The overdrive is a 2 position switch and the indicator is a 3 position one. They both have an upwards bend in the stalk. So if you flip the column both will droop downwards. I had the same problem in reverse, converting a left hand drive car to right hand drive. You will have to buy 2 new switches. Also, the wiring in the top of the column is very tight and it is easy to cause a short if you do not run the wiring carefully. I would not be twisting them!
Good luck.
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
A turn signal knocked off center Austin Healey 14
D TR2/3/3A Turn signal cancel? Triumph 11
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
