Aloha c-man,
Look carefully at that turn signal cancellation "bump". It should be a spring-steel clip that snaps onto the column...albeit with some difficulty. Look opposite the 'bump' for a split; you can spring it open and pop it off the column and refit the other way. There should be two 'pips' in the clip that hold it in place. I'm going off memory of my long-ago TR4, but I think the TR6 is the same way. I have one of them somewhere, but would have to dig it out of a box. Also, early TR4s used a turn signal switch with a single canceling 'finger'; later TRs through the 6 use the more common switch with two 'fingers' and a 1-bump clip on the column. Should be no need to pull the wheel unless you want the signal cancellation function and steering wheel to all be centered.
Jeff
59 TR3A & 63 TR4 (in mainland storage):sorrow:
