TR6 TR6 Oil Pressure issues
howie18
Dear All,
I just picked up a '73 TR6, which I love. It is in pretty good shape. When I got it several weeks ago, the oil pressure was fine, about 40 psi at idle. Now, it has fallen to about 10 psi at idle and does not rise significantly at higher rpms.
Are there any "known" or "common" problems that might cause this or is there anything in particular I should look at first?
Thanks in advance for any help in this matter.
Howie
Administrator
Boss
Originally posted by howie18:
Dear All,
Howie
I'm not that familiar with the TR6, but if it's anything like a Jag EType, and has an oil pressure relief valve, make sure that is in good working order. Of course make sure you have good clean oil and filter too. Any major leaks?
hlub34a
Dear All,
First..what changed other than the oil pressure? did you change oil? Do you have the original cannister filter or a spin-on unit? How is the oil consumption? Have you added any?
I have a very original 73. I run 20/50 Valvoline and the pressure is about 60 lbs. After it's warmed up the pressure goes to about 20 at idle, but goes back up at road speed.
It could be that the gauge is bad. Is there any way you could put another gauge on to check?
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
B TR6 TR6 High Oil Pressure Triumph 20
sundown TR6 1973 tr6 oil pressure light Triumph 3
I TR6 75 TR6 Oil Pressure Switch replacement Triumph 16
sundown TR6 TR6 oil pressure Triumph 7
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
RomanH TR6 '74 TR6 Oil Pressure switch Triumph 7
glemon TR6 TR250 TR6 no oil pressure after rebuild Triumph 20
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
mabbott TR6 73 TR6 oil pressure switch Triumph 4
T TR6 TR6 Oil Pressure Triumph 49
Brosky TR6 3-Prong TR6 oil pressure switch Triumph 13
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
hondo402000 TR6 TR6 plastic oil pressure line Triumph 2
I TR6 TR6 oil pressure information Triumph 7
hondo402000 TR6 OIL pressure gauge Needed 71 TR6 Triumph 10
B TR6 TR6 Oil Pressure Triumph 2
hondo402000 TR6 oil pressure gauge TR6 Triumph 5
R TR6 TR6 Cylinder Head Oil Line effect on oil pressure Triumph 10
F TR6 Oil Pressure Warning Light...TR6 Triumph 6
F TR6 Oil Pressure Relief Valve- TR6 Triumph 2
V TR6 TR6 Oil Pressure Reading Triumph 11
Slider748 TR6 High oil pressure in TR6 Triumph 17
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
A TR6 spin on oil filter for tr6 Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
M TR6 '72 TR6: Oil in Coolant Triumph 25
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
D TR6 Tr6 oil pan Triumph 3
A TR6 TR6 Aluminum oil gallery plugs Triumph 4
Gerry M TR6 TR6 gear oil Triumph 8
B TR6 Oil in a grease gun for TR6 lower steering swivel? Triumph 16
T TR6 Will a 71 TR6 oil pan come off in the car? Triumph 3
TRclassic3 TR6 TR6 Leaking oil gallery plug Triumph 5
Woodie TR6 tr6 oil change Triumph 5
Mike_Roe TR6 Oil usage - TR6 Triumph 8
T TR6 TR6 oil loss/usage Triumph 28
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
B TR6 TR6 rear axle oil change Triumph 21
B TR6 TR6 Oil Cooler hoses Triumph 1
I TR6 TR6 oil sending unit thread size help please? Triumph 12
W TR6 TR6 Timing chain oil seal question Triumph 3
F TR6 TR6 Oil Folter Removal Triumph 10
I TR6 TR6 oil suggestions Triumph 9
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
