TR6 1973 tr6 oil pressure light
sundown
Pretty much have the wiring figured out although the hazard switch will only work with ignition switch on and the oil warning lamp stays on?
If wired correctly the OP light will never be illuminated by itself. The OP light is always accompanied by an illuminated "BRAKE" light.
However a problem with the brakes that would cause the "BRAKE" light to illuminate will NOT also illuminate the OP light.
No comment on the hazard light except to say that's not right either.
The brake light is also on with the oil pressure light but they do not turn off once the car is started
I guess there are a couple of things that could account for that, but my first stop would be at the switch, making sure that the White/brown wire was on terminal "S" and not on terminal "P"
