CraigLandrum
What is the proper height of a TR3A seat cushion both in front and in back? My old rusted-out spring-based seat cushions measured 7 inches in front from the edge piping to where the side material curves under the bottom of the spring frame, and on the back, measures 4.5 inches from the edge piping to the spring frame. I can't use the old springs and for cost reasons have decided to use foam but wanted to get close to the proper dimensions. I do realize that the cushion domes a bit above the piping, but the piping seemed the best reference point.
So - can anyone confirm these front and back measurements or supply the correct ones?
Also, if anyone out there has cut their own foam for seats, I would appreciate some tips - especially on the cushion. Did you cut the cushion to slope backwards from 7 inches to 4.5 or what? Are the left and right sides cut with a slight inward slope or is this achieved using upholstery batting around the edges? I've seen the helpful set of pics that showed a set of foam seats being constructed with heaters but the pics didn't state any dimensions and it wasn't apparent that the foam was cut on a slope.
If nobody can supply any tips, I'll assume that I need to cut a sloped cushion with the above dimensions and then provide extra padding using upholstery batting to get a tight looking fit.
