TR2/3/3A TR3 engine removal
Adrio
I have been spending way too much "pleasant" time under the bonnet of my TR3 with solvents removing rust proofing and tar etc. preparing to paint my engine bay. While wiling away the hours there I was looking about and wondering....
Could the following be done with lots of car and finesse without removing the front apron (or has anyone ever attempted it or done it)
-remove the fan without removing the rad
-remove the hub extension via the starter hole in the rad
-remove the frame cross piece (I suspect yes)
-remove the tranny (I know this can be done I did it)
-remove the water pump, generator and crank pulley
-remove the engine (which is my real question, is there some sneaky way to get the engine out without removing the apron - since the DPO welded my apron in place)
Like I said I have spent too much time staring at things under there and I was inspired by my in car steering box rebuild success.
TR3driver
Great Pumpkin - R.I.P
The fan can be done (BTDT). Once the dog bolt is out through the crank hole, the extension can be unbolted from the hub and taken out to the side (ditto). Then the hub can be removed as well.
Everything else you mention, I've done, except for the engine block itself. Offhand I don't see why it wouldn't be possible; but I've never tried it. The camshaft & its bearings are about the only thing that can't be changed with the engine in the car, anyway.
bgbassplyr
If you hold your mouth just right, it can be done.
A
Adrio
Thanks for the replies. by the above are you saying I can rebuild the engine (rings, bearings, pistons etc) while the engine is in place as long as I don't want to do the cam or its bearings?
I guess this is how a project can grow out of control, but if I were to remove the engine this way, does that mean the rad can then come out the engine compartment?
This is starting to look like my next major project on this car.
And Jim, holding my mouth just right seems like a small price to pay.
MDCanaday
Have you ever tried a valve job by going up the exhaust pipe??? there comes a point where you are working hard to avoid a little effort.On a tr3 its good karma to pull the apron and cherry out the cooling system and the front of the motor.Get a front seal,timing chain ect and do a nice job of freshening up the old lump.She will reward you with many smiles per gallon latter.Dont forget to service the generator and its bolts too!!
MD(mad dog)
bgbassplyr
Removing the fan, fan hub, and cross bar should allow the rad to be removed. Again, if you're willing to pay a small price. Buy one, get the second one free.
TR3driver
Yup. I've never pulled the crank with the engine still in the car; but with the gearbox out I think it would be possible. But I have changed liners, pistons, rings & bearings that way.
Not a "rebuild" by my definition, but good enough to run for a long time. The short block that I'm pulling out of TS39781LO today hasn't had the crank out of the block in over 100,000 miles; and quite possibly never since it was new (although it's not the original engine). The first engine I "rebuilt" that way (after it swallowed a valve) is still running almost 35 years later, but probably hasn't done as many miles.
PS, I think to remove the radiator with the front apron in place, you also have to remove the cylinder head. I've heard it can be done, but haven't done it myself.
rlwhitetr3b
Bronze
MD(mad dog)
He said that the DPO welded the apron on. This might need to be added into the equation of the "best" way to do these repairs.
A
Adrio
Indeed the DPO had welded it on in places. However, between the chats on here, the time I am spending cleaning the tar, just thinking and looking I realized it is folly to own a TR3 with an apron that can't be removed (never mind the fact I have owned one like that since 1979). And, given the fact part of this project was to paint the engine bay and that means I will have matching (I hope) paint in a gun to fix anything that might go wrong.
Sooooooo, I spent today very carefully cutting the welds I could find in the wing-apron seams, trying not to damage the paint or body work on either side. A few hours later and with the help of friend, the apron is off.
Now I can do a proper job of painting the engine bay and while it is apart like this I am having the radiator re-cored (any suggestions on that). Should I ever want to rebuild that engine or get at the rad or steering box, I know that with a few hours work I can get the apron off and the pull the engine, road or steering box.
Thanks for the motivation. And I won't blame anyone but myself when this quick project takes more then half the short Canadian summer.
Twosheds
Good call.
O TR2/3/3A TR3 engine removal Triumph 5
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
Pool Dad 1960 TR3 engine serial number Triumph 14
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
Moosca TR2/3/3A "56 TR3 Engine Verification Triumph 17
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
J TR2/3/3A TR3 engine build Triumph 12
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
6 TR2/3/3A Engine in my TR3 Triumph 15
M TR2/3/3A TR3 engine hood wanted Triumph 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
5 TR2/3/3A TR3 engine building tips needed Triumph 5
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
D TR2/3/3A tr3 engine Triumph 6
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
V TR2/3/3A TR3 Engine Noise Triumph 33
NutmegCT TR2/3/3A TR3 engine question Triumph 6
MGTF1250Dave TR2/3/3A Questions about Breaking in a refreshed TR3 Engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
K TR2/3/3A TR3 Engine block marking? Triumph 4
G TR2/3/3A TR3 Rear engine seal issue Triumph 13
T TR2/3/3A TR3 engine ground Triumph 9
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
C TR2/3/3A tr3 engine numbers Triumph 23
MGTF1250Dave TR2/3/3A TR3 Engine Hoisting Fittings Triumph 5
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
K TR2/3/3A TR3@70mph engine seemed to "flatten out" or..... Triumph 10
GBRandy TR2/3/3A TR3 Engine Bay Color Triumph 5
