I took a water pump from a 4A and mounted it to the pump housing on the 3. The impeller on the pump spins freely when off the housing but when I mounted it to the housing it was extremely stiff to turn the pulley.( It's not rubbing on the outside of the pump in the area where you sometimes have to grind off the housing where it rubs on aftermarket pumps). I removed the pump and added another gasket thinking that the butt end of the impeller was somehow hitting the back of the pump housing.(later looking inside the housing cavity I don't thin k that would be an issue anyway.) The pump pulley is still stiff to turn. I'm going to mount the 4A pump housing to see if that makes a difference. Should the pulley spin just as freely off the housing as it does on?How freely should the pulley spin when everything is set up right?
