First thing you need to do Zimmy is remove both fenders (11 bolts in each) 4 bolts inside under the kick panel, 4 bolts under the hood, one at the corner going down up in the corner, one up under the inside corner going into firewall, then two at the bottom under the hood going down into the hood latch panel. Then 3 down at the bottom from the fender to the valence panel. Your gonna have to beat them back out. Also take the hood off Then there are a bunch of bolts holding that valence/hood latch panel on. If you aint got the money and just want to drive it, you can beat them all out good enough for proper function and look for more front end stuff and still have it drivable. You do need a front clip. That includes both fenders, the hood and the hood latch/valence panel. Those panels could be made to be right again but it would be a lot of work. I just put the front end back on mine and got it primed and all, so its all pretty fresh in my mind if you have any questions.
