SS Exhaust Systems - BELL vs. FALCON
gonzo
I’d like to replace the entire exhaust system on my Healey BJ-7 and upgrading to stainless steel. Installed now is a custom mild steel exhaust system with aluminized (dual) separate glass packs that’s starting to age and may be affecting engine performance due to its design.
By comparison the Healey’s stock system may have better balance since exhaust flow is into one muffler (and/or resonator) providing needed back pressure.
Anyway, when considering complete stainless steel exhaust systems, is there any different between FALCON, which is readily available, and BELL with regard to sound, performance, fitment, cost etc. Thanks in advance for sharing your opinions and experiences. GONZO
Keoke
Gonzo, go with Bell they most closely resemble the original exhaust fitments so SHG tells me---Keoke- /ubbthreads/images/graemlins/yesnod.gif /ubbthreads/images/graemlins/grin.gif
SHG
yup. installation was smoooooooth. one of the few things that ever fit exactly right out of the box.
bighly
The Falcon systems are cheaper but do not fit well out of the box. They are close enough to install with some spacers but not a direct fit. If you are good at SS welding or if Falcon corrected their mount points since I got mine 5 years ago. ............
AUSMHLY
Hey Mitch,
Just a heads up. Do any parts, original, aftermarket, borrowed, home made ever just plug in?
I spent a lot of time on my exhaust, mostly modifying the support brackets to take the not perfect fit of the exhaust, off them.
One of the problems is, that if the metal/rubber support brackets have any unnecessary strain on them, the rubber will eventually separated from the metal bracket it is glued too. Ask me how I know that.
We live close to each other. Your welcome to come take a look see at mine and I'd be happy to help should you need a hand or someone to run get you a Band-Aid. No Healey job would be complete with a scratch, bruise or cut.
Cheers, Roger
G
gonzo
Based on information shared by helpful individuals, a BELL SS exhaust system will be installed in about 6 months. Fortunatly, a BJ-7 system is easier to install b/c it lacks the additional resonator and associated hangers, clamps etc. Until then the custom glass pack system will have to suffice. Thanks again for the impressions - Roger, thanks for your kind offer - we should plan to meet (FYI Hot August Nights - Danville admits only pre-60's cars to display so our car's don't qualify.) GONZO
AlanT
OK , The forum feedback convinced me to use a Bell System. Now,Who supplies a Bell systen in the US.? A google search did not turn up much. Thanks....
Alan T
Keoke
/ubbthreads/images/graemlins/savewave.gif
Pegausus Racing has SS "T" bolt exhaust clamps.---Keoke
PAUL161
Odd, I bought two Falcon stainless systems, one 10 years ago for a 72 MGB and one 4 years ago for a 1955 MGTF 1500 and both systems were a direct bolt up with no issues. Everything fit perfect and both systems are on the cars now. PJ
Stretch
My BJ7 Bell muffler is not a straight through design. You can see blanking inserts when looking down the bores. The noise level is less but the resonance points are less noticeable too so the exhaust "song" is less distinctive. I am not able to feel a difference in performance.
steveg
FWIW - my Monza exhaust's loudness (85DB) was getting to me, so I briefly reinstalled my 1.5" Bell SS tailpipe with my Moss mild-steel muffler. Just as loud as the Monza but with nasty stainless steel resonances thrown in. Probably works better with Bell's own muffler.
S TR2/3/3A Exhaust Systems Triumph 10
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Simmo MGB Exhaust Systems MG 10
BOBBYR Exhaust systems ? Austin Healey 2
T Swapping exhaust systems on a Sprite Spridgets 3
TonyPanchot Exhaust systems/ mods Triumph 15
R E Type Exhaust systems Jaguar 2
R exhaust systems MG 1
tahoe healey stainless exhaust systems Austin Healey 3
7 Exhaust systems MG 17
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
