• Dear Guest!
    If BCF is a useful resource for you, if you appreciate not having Ads pop up all the time, and if you want to ensure we can stay online -
    Please consider supporting us by **Upgrading**
Spax conversion kits for 58 sprite
sim
HI
Any reviews on Adj gas shock conversion kits from SPAX
this would be on the rear.
like better handling or worse>
Thanks
sim
Pythias
Peter the Parts Pimp has adjustable lever action shocks....
FYI
NFI
YMMV
etc.
Jim_Gruber
Does that demonstrate your opinion of the kit?
bug_sixty
the rebound for what ever reason, only a engineer might know, just plain doesn't work. The ONLY one is the OEM Armstrong with the proper length link. Of course, some racers out there have their secret setup but for the rest of us stay OEM.
apbos
Peter Caldwell is making Adjustable Shocks using the stock Shocks and then making them adjustable like the very rare Armstrong 22's Peter Caldwell adjustable shocks
Paul
sim
sim
HI
Thanks for all the help
i will stay with OEM
Now how can I tell if they are not working?
Pythias
The standard test will tell you if they need to be looked after. Push down on one corner of the car at a time and let go. If it cycles more than 2 two times, they're no longer functional. Take them off and send them to PPP. (NOS Imports) and let him do his thing. You'll never regret it afterwards. Never.
NFI
YMMV
IMHO
etc.
sim
sim
with 1/4 epileptic rear springs that test does not work
The fronts are ok
I guess i will need to remove them and see how they feel
Jim_Gruber
If there are any signs of lekage send them off to Peter C. He is the absolute master of rebuilding Lever Shocks. He and only he knows the special secret to make these better than new from the factory.
NFI just a very satisfied customer of Peter for the past 12 years.
F Rear shock conversion and correct SPAX? Triumph 1
SCguy Spax Shocks for KYB Shock Conversion Kit Triumph 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
G Spax Bugeye kit NLA? Spridgets 2
Gerard Spax rear shocks on Bugeye Spridgets 12
YYCDave Externally Adjustable SPAX Shocks - Really? Triumph 1
malice Spax? Good deal? Triumph 2
D TR2/3/3A SPAX on TR3A? Triumph 1
G Spax or Koni? Triumph 6
D Spax adjustable shocks Triumph 0
R Smitty Toyota Conversion Angle Drive Austin Healey 16
P Positive to Negative Conversion Austin Healey 1
P Pos to Neg Conversion Austin Healey 1
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
A For Sale TRIUMPH TR6 Electronic Tachometer "Racetorations Conversion" Perfect condition. Triumph Classifieds 0
D transmission conversion Other British Cars 1
W TR2/3/3A Wire Wheel Conversion Triumph 5
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
petnatcar Breather Hose Conversion Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye disk brake conversion Spridgets 10
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
Walter74 Throttle Cable Conversion Austin Healey 6
PAUL161 T-Series Dynamator Alternator conversion. MG 23
M Dynamo to "Dynamator" Conversion Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
H Shock absorber conversion Austin Healey 3
S MGB MGB engine conversion MG 12
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
J TR6 Moss HS6 SU conversion kit question Triumph 4
roscoe 5 speed conversion question Austin Healey 9
maxwedge5281 bought back my first nasty boy conversion!! Austin Healey 6
I Bug eye front disc brake conversion. Spridgets 5
steveg Cost of V8 conversion Austin Healey 34
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
M TR6 5 speed conversion Triumph 33
C AUF214 solid state conversion question British Motor Corp 0
