Solution for brighter dash lights?
ichthos
I don't know if it is because I am getting older, but I could really use some brighter lights for the dash in my TR6. Does anyone have a simple solution? Thanks for your help.
Kevin
poolboy
Have you electrically bypassed the dimmer? You'll get full voltage..not that it'll make a world of difference.
glemon
I
ichthos
Even at the brightest setting, I have difficult seeing. Even if I bypassed the rheostat, Poolboy, it wouldn't get any brighter would it? I will check out the links, Glemon. Thanks.
Adrio
what about lining the inside of the guage with chrome foil from the hobby shop?
John_Mc
Brosky has a really nice gauge refinishing section on his website that I think addresses that problem.
poolboy
Mine did and I attribute it to carbon build up on the contacts in the rheostat (dimmer) contacts.
If you can feel the metal housing of the rheostat, turn the lights on full for a few minutes and if you feel warmth, then you are loosing voltage to the lamps due to some resistance.
You asked for 'simple', right? ...that's the simplist thing you can do. Anything else will involve taking the rheostat apart for cleaning, removing each and every gauge and/or replacing each and every bulb.
Just interconnect (in any order) all the wires you find plugged into the rheostat. If it doesn't satisfy you, keep on going..bulbs, gauges, paint, etc.
JerryVV
I had the same issue until I went to the eye doctor and found out I had Cataracts. Once that was fixed everything is brighter. So if you once had no trouble seeing the dash gauges and now you do it might not be the bulbs. In my case I had no idea that my eyes were as bad as they were until after the surgery (which is very simple these days). Just another solution to a problem that may not have been considered.
TR3driver
Great Pumpkin - R.I.P
FWIW, it might be worth trying a new standard bulb. All incandescent bulbs get dimmer over their lifetime; and those Lucas bulbs seem to be particularly bad about losing output without actually burning out. I have several of them where the bulb is totally black!
Also, I agree entirely with poolboy. It may not help, but it might help and it's easy (and cheap) to try.
Don't know if it's a problem on the TR6, but the TR3 small gauges use plastic windows that can overheat, melt and/or blacken if they get too hot. Using higher wattage bulbs might not be a good idea, especially if you ever drive long distances at night. Higher wattage bulbs will also likely have a negative effect on the dimmer (which is none too strong in the first place).
glemon
LEDs produce less heat and use less juice, also last longer, caveats, are the bulb shapes are usually different, you have to make sre you get one that fits, also they can be (depending on design) highly directional, for your isntrument lights you generally want a design that spreads the light evenly, you can get LEDs that do this, but many of them don't, so you need to check the specs.
As usual, I agree with Randall and others, try the easy and cheap stuff first and escalate from there.
Brosky
If the plastic is dirty or blackened, no bulb will help. If the paint is all tan and flaked, the new bulbs still won't shine brightly.
It's some work, but if you do it my way, they will be bright. https://www.74tr6.com/gauges.htm
6TTR3A
<span style="font-size: 12pt"><span style="color: #003300">The TR6 gauge lights have a blue tint to them. This is achieved by the riveted insertion of a blue plastic blister inside the gauge itself.If you're not satisfied with the quick & easy fixes, remove the gauges, take them apart (it's not that hard)& remove the blue blisters. Replace the bulbs with new ones. (Randall is right, they get dimmer with age) I did this for a friend & he was AMAZED!!!
Frank </span></span>
hondo402000
you can go one step further and sand blast the inside of the gauge housing and paint them gloss white, I did all mine and got rid of the plastic tint things and I can now see the gauges very well. I also soda blasted the rheostat wires and cleant the contacts and it works very well now too
Hondo
I
ichthos
I did take my gauges apart on my Bugeye and did the works like Paul and others of you did. I was able to find new plastic (it is all flat in a Bugeye) that would work since the old stuff was pretty much opaque after 50+ years. I read Paul's article quickly, but I didn't see if he put the old blisters back, put in new ones, or simply removed them. Are the blue blisters available anywhere?
Kevin
myspitfire
<span style="color: #3366FF"> </span> <span style="font-size: 11pt"> </span> :smile:Hi Kevin;..All of the above would most likely work ok.Before i tear anything apart i've used this product; Is called "BLUE WORKS" From the makers of 'WD40'This is what it says on the 12oz spray can;'Elecrical contact cleaner'industrial grade'
1.Quick drying formula
2.Plastic & metal safe
3.nsf(reg)k2 (reg)
On the back it says;
CLEANS SENSITIVE ELECTRONICS & ELECT EQUIP,DIELECTRIC STRENGTH 25,000 VOLTS,Top grade product by wd40 co.Spray directly onto or into the the circuit contacts to eliminate any contaminants that may cause LOSS OF ELEC CONTACT,THE SPRAY WILL DISOLVE QUICKLY,THE CONTACTS WILL BE CLEANED.Its a non-toxic spray.
I use it on ALL my cars & IT WORKS,My Brit cars all had the treatment.Best part especially the lighting does appear brighter.I bought mine at an industrial supply store,NAPA should carry it.
Ken
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
B MGA Solution! 1600 harness in a 1500 MG 1
B MGA Front bumper solution!! MG 1
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
steveg Anti-run on solution Austin Healey 10
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
H TR4/4A A simple solution for separating axle and hub. Triumph 32
TomMull Air Compressor Solution? Restoration & Tools 8
S New/Old Solution for Hardtop Headlinner Restoration & Tools 2
PC storage solution Restoration & Tools 2
I Solution for gas leak? Spridgets 1
J Split steering wheel solution? Triumph 3
fogliner My HS4 plumbing solution MG 13
K Brake squeal solution.... Triumph 4
T Radio/speaker solution for BJ7 Austin Healey 12
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
JPSmit Tonights curious solution Spridgets 3
Cyberpyr8 Need help finding a solution Triumph 23
jlaird A solution, maybe Spridgets 2
JPSmit elegant solution needed Spridgets 6
T Our solution to our parts problem.... MG 10
healeynut Hilly Healey Gas Tank Woes - Solution? Austin Healey 11
R T-Series MGB Clutch Bleed Solution MG 5
Monark192 Solution to electrical problem MG 8
zimmy stuck in reverse....solution? Spridgets 2
J MGB 6ft3, MGB - only solution to chop my legs off? MG 12
S tachometer wanted...or solution? Spridgets 26
B TR6 TR-6 Steering Boot Assembly - THE Solution Found?? Triumph 2
Mark_Gibson TR6 Positive Camber Solution for TR-6 Triumph 0
X Solution? Jaguar 6
edkap2002 TR6 Brighter instrument lights? Triumph 0
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
T BRIGHTER DASH BULBS.......anyone have numbers Spridgets 10
PAUL161 Brighter Lights-[Cheap] MG 1
healeyboz brighter side of things Spridgets 7
AUSMHLY How to: Brighter gauge face with LED’s. Austin Healey 78
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
A brighter light... Triumph 15
G Rear lights brighter than ever.... Triumph 1
Brosky Brighter dash light bulb saga continues Triumph 17
A Brighter Smiths Instrument Bulbs --- Any ideas? Austin Healey 25
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
