elegant solution needed
JPSmit
Like most everyone, I'm not reinstalling the pollution stuff. This does however mean that some hoses are going uninstalled. Does anyone have an simple yet elegant solution for plugging these pipes?
bigjones
Bronze
Hi there,
If you are talking about the holes left in the cylinder head, there is someone on Ebay selling Allen-headed grub screws.
The ones I got were advertized as brass but they look like steel and stick to a magnet, ha! Not sure if that is a problem but so far OK.
Cheers.
ChrisS
I cut down 7/16" fine thread bolts to about 3/8" 1/2" and put brass washers under to seal them. I'll try to post a picture later.
58Custom
Here is one of the Ebay auctions for the AIR tube hole plugs.
https://tinyurl.com/3hb3eo
(AIR is a Ford term, but I mean air pump)
They are just allen head set screws. I have a set in mine. Install with Locktite.
Dug
How about 7/16"-NF set screws? flush fit and a cone at the tip for the seal? Steel or brass or even stainless. Easy and clean.
"dug"
John Moore
You can buy those allen head screws at any half decent hardware store.
JPSmit
JPSmit
Oops - let me clarify - Those holes are filled - I'm talking water & air - anything other than the air rail - for instance, the pipe that goes from the water pump under the manifold to the heater box has two outlets - I only need one - what to do with the other? Likewise, the intake manifold had a line come in and the carb also.
K The Elegant Bentley Continental! Other Cars 2
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
B MGA Solution! 1600 harness in a 1500 MG 1
B MGA Front bumper solution!! MG 1
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
steveg Anti-run on solution Austin Healey 10
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
H TR4/4A A simple solution for separating axle and hub. Triumph 32
TomMull Air Compressor Solution? Restoration & Tools 8
S New/Old Solution for Hardtop Headlinner Restoration & Tools 2
PC storage solution Restoration & Tools 2
I Solution for gas leak? Spridgets 1
I Solution for brighter dash lights? Triumph 14
J Split steering wheel solution? Triumph 3
fogliner My HS4 plumbing solution MG 13
K Brake squeal solution.... Triumph 4
T Radio/speaker solution for BJ7 Austin Healey 12
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
JPSmit Tonights curious solution Spridgets 3
Cyberpyr8 Need help finding a solution Triumph 23
jlaird A solution, maybe Spridgets 2
T Our solution to our parts problem.... MG 10
healeynut Hilly Healey Gas Tank Woes - Solution? Austin Healey 11
R T-Series MGB Clutch Bleed Solution MG 5
Monark192 Solution to electrical problem MG 8
zimmy stuck in reverse....solution? Spridgets 2
J MGB 6ft3, MGB - only solution to chop my legs off? MG 12
S tachometer wanted...or solution? Spridgets 26
B TR6 TR-6 Steering Boot Assembly - THE Solution Found?? Triumph 2
Mark_Gibson TR6 Positive Camber Solution for TR-6 Triumph 0
X Solution? Jaguar 6
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
H TR2/3/3A Rock guard needed Triumph 2
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
P MGB Zenith water choke gasket needed MG 4
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
T Wanted BJ7 parts needed Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
