Brake squeal solution....
karls59tr
Bronze
I read on another forum where someone cut two diagonal slits in the brake pad material down to the back plate so that accumulated brake dust had a place to drain thus reducing brake squeal. Anyone done this?
jsfbond
Brake noise is from the back of the pads. Vibrations move the pad against the piston and the bracket. Noise reduction should start on that side with shims or the CRC disc brake quiet #05016. If your brake pads are not offered with shims many parts stores can order them separately. The material can be cut with shop scissors if an exact match to your pad shape cannot be found.
PeterK
You can also try chamfering the leading edge of the brake pads 1/4" or so. Just enough so the leading edge (the edge that the rotor passes first as it spins when going forward) doesn't immediately contact the rotor. Use a file or disc sander to knock off 1/4x1/4. Then (sparingly) use the CRC blue disc brake quiet on the back of the pads.
startech47
If you cut the slits you want one section to be a little longer than the other. This forces each section to be resonant at a different frequency and reduces the energy at a single frequency.
PAUL161
I use Kevlar pads and have no problems with squeal on the MGB. I had a problem like that on my truck and did the same to solve the problem. It worked! PJ
K TR2/3/3A Front disc brake squeal.... Triumph 4
johnrip Wedge TR7 Brake squeal Triumph 1
60TR3A Brake Squeal Austin Healey 13
I TR6 TR6 brake squeal Triumph 8
CraigLandrum TR2/3/3A TR3 front disk brake squeal cause? Triumph 11
GBRandy Wedge TR8 Rear Brake Squeal Triumph 10
S Mundane brake squeal Triumph 13
jerrybny Front Brake squeal Triumph 5
RobT Anti-Squeal Shim & Other Brake Questions... Triumph 15
Frank C. Disc Brake "Squeal" Austin Healey 7
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
