brighter light...
artpart
Member
One of my headlights went out today and so I got to thinking about upgrading to brighter lights. Has anyone installed halogen lights? If so, have you also installed the heavy-duty headlight harness?
T
TRDejaVu
I just put Halogen sealed beams from NAPA into my TR4 as a straight swap after one of the earlier non-halogen beams went out. I have a dynamo (generator) and it all seems to work fine without any changes to the wiring harness. I keep feeling the light switch body for overheating, but it doesn't appear to be any different than before and the wires seem fine as well. Obviously I can only comment based on what I have experienced with my car.
PeterK
I had been running sealed beam halogens on the stock harness on the 3A without any problems. The sealed beams produced a much whiter and brighter light than the conventional bulbs
But now, I am adding 2 relays (finishing up the install tomorrow) for a H4 halogen conversion.
The benefit of the relays (sealed beam or H4) is that the power to the lights is direct from the power source (battery post or starter solenoid terminal), rather than through the switch and wiring harness. With direct power, the lights get the full 12V and produce better light as there is no voltage loss through the harness. Also the load is not carried ny the headlight switch when using relays. Part of my project was also to rewire the headlight socket harness with a new set from British Wiring.
G
What condition is your wiring harness in? Is it the original? If you have no other electrical upgrades on your system and the harness is in very good condition, you should be ok with simple H4-bulbed headlights. Installing a relay would take the load off the headlight switch. Remember, the headlights in your car are not fused, do not add such. Do you have a copy of Dan Master's book on TR6 electricals? Worth every penny from Moss and TRF. Goes into great detail on anything and everything electrical.
T
Tinster
Bill,
On a side note of general interest concerning wires
and the aging process.
You remember I installed the entire car Dan Masters Power
Block wire harness back in October for my TR6.
Yesterday I had to cut a few wires to strip some paint
under them. I was really shocked at how quickly the bright
coppers wires inside the PVC coating had turned black in 6
short months. And Dan's wires are much heavier gage that
the Triumph originals.
I wonder what condition a 40 year wire harness could
possibly be? I have to believe an awful lot of resistance
has built up over the years.
d
PeterK
I agree on the fuses but I noticed than Dan Master's headlight relay harness adds a separate fuse for each lo-beam and hi-beam, 4 fuses total. This way you can protect the wiring with a fuse but not have all the lights go dark if a single fuse blows (if you just protect the wiring with a single master fuse.)
kodanja
Concider Lucus PL700's, they are very bright!
T
Tinster
PeterK:
When I installed the new Dan Master wire harness,
I also installed a non-fused set of small halogen
driving lights beneath the front bumper. These are
emergency driving lights controlled with an on/off toggle.
Given my TR's propensity to have things suddenly quit
functioning, I thought it prudent to install the emergency
set of lights.
And they light up Wendy's orchid room really well.. while
the car sits on jack stands!!
regards,
d
Andrew Mace
Tinster said:
You remember I installed the entire car Dan Masters Power Block wire harness back in October for my TR6.
possibly be?...
Oddly, in many such "aged" wire harnesses I've dealt with over the years, the wire inside was just fine! Maybe, like so many other things nowadays, wire "ain't what it used to was...." /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
PeterK
I think the best quality copper core is used in high-quality speaker wires that are 99.99% oxygen free copper wire.
Copper containing oxygen will oxidize more rapidly but wire shouldn't turn black in 6 months unless exposed to chemicals.
Copper hasn't changed over the years but the way it is made has and for the better in most cases.
R
RonMacPherson
Did you let Dan Masters know of this?
I think he might like to know so that he can have a chat with his suppliers. Rapid oxidation in the harness, increases resistance, increased resistance leads to all kinds of electrical problems.
May I suggest that if you still have the capability of taking pictures of the oxidized wires, do so and send him the pictures.
It will better all of us.
TR6oldtimer
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I was really shocked at how quickly the bright
short months. [/QUOTE]
Dale, you live in a humid, salt air environment. I would have expected the copper to turn green, not black. As I recall you soldered the spades and lugs onto your wires. I assume you were using flux solder, if so, this would cause the wire to turn black.
Just a thought.
Geo Hahn
Andrew Mace said:
...in many such "aged" wire harnesses I've dealt with over the years, the wire inside was just fine!
Indeed, I have an old TR4 harness that I occasionally cannibalize for wire and connectors (like to use the correct color code for auxiliary lights, etc). Just stripped some the other day and the copper was still clean & coppery.
TR3driver
Great Pumpkin - R.I.P
FWIW, I wound up with 90/100w H4s on my "late" TR3A. Used the original harness out of the buckets, but ran new wires to the bullet connectors on the inner fender (mostly because a previous mishap had melted the wires inside the harness).
Bought a "headlamp upgrade" relay from JCW, that included two relays and two fuses all inside a single, sealed box. Of course, I had previously converted to an alternator to power those oversize headlights.
The result lit up the road wonderfully. Even at 70 mph, I finally felt I could see far enough down the road to stop before any unforseen obstacle. Reflective signs were visible for over a mile. And several people at VTR commented on how bright my headlights were.
Don't know if JCW still sells that relay box, or if I would go the same way again. But here's a similar one on eBay :
https://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180130776769
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
Brosky Brighter dash light bulb saga continues Triumph 17
edkap2002 TR6 Brighter instrument lights? Triumph 0
I Solution for brighter dash lights? Triumph 14
T BRIGHTER DASH BULBS.......anyone have numbers Spridgets 10
PAUL161 Brighter Lights-[Cheap] MG 1
healeyboz brighter side of things Spridgets 7
AUSMHLY How to: Brighter gauge face with LED’s. Austin Healey 78
G Rear lights brighter than ever.... Triumph 1
A Brighter Smiths Instrument Bulbs --- Any ideas? Austin Healey 25
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
D TR2/3/3A 3D printed tail light Triumph 12
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
B Positive-Ground LED Light Strip Austin Healey 8
bigjones TR2/3/3A Rear tail light not budging Triumph 5
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
F TR2/3/3A head light buckets Triumph 3
G Brake Light Switch Failure Austin Healey 24
J TR2/3/3A Red ignition light stays on Triumph 7
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
C MGB-GT Reproduction light switch MG 13
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
T Tail light extension Spridgets 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
6 E-Type brake light pressure switch location Jaguar 5
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
R side light install Spridgets 2
S TR6 Oil Pressure Light Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Cappy Ignition Warning Light Austin Healey 6
I TR6 Dash light issues Triumph 19
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
B Brake light weirdness Dodge Ram Other Cars 5
JPSmit I saw the light! I saw the Light! Restoration & Tools 19
P TR2/3/3A TR3B Panel Light Switch Triumph 20
D TR2/3/3A center panel indicator light color Triumph 10
D TR2/3/3A Brake light switch. Triumph 22
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
