It is I have owned the car since the 70s and it has been stored inside nearly all the time since.
basically a solid car, but so not to hide anything, I will list any areas that will need extra work.
The major exterior body parts have been sandblasted and the aluminum was hand stripped. The chassis has been painted over but never touched otherwise.
Rocker panels need replaced but the inner fender wells are dented but solid.
There is a used right rear wing with minor damage to replace a bad one. The other wings are good, as are the doors. I’m not claiming they are perfect, just need minor work. The boot is the worst, it is solid, but has had putty on it that will need replaced.
The shrouds are OK. There is some repaired damage on the right front around the parking lights.
Sorry there are no close ups of the panels. I will have to get them down from the loft if you want pics.
The engine has not run for many years, but I did oil the cylinders. I’m going to try to pull the head to take pics. It was rebuilt when I bought it from a Forgien car repair garage. Brought it home, installed the engine and would drive it around the block occasionally unfinished until it was put in storage.
I included a few pictures soon.
I can answer more questions if you have any and thanks for the interest.
