self-levelling system
soverign1
hi,i have a 1988 jaguar xj6 soverign which i purchased in toronto and drove back to newfoundland,the suspension was fine until a few weeks ago,when i start the car in the morning the car rises to its full ride height and after 1 minute it deflates itself and does not rise anymore and the car bounces excessively,any help would be greatly appreciated,thx,Robert
jessebogan
The shocks are bad. The cheapest and most permanent solution is to convert it to "normal" rear shocks. Kits are available from most of the Jag parts vendors. My personal choice would be to avoid the KYB shocks, as they seem harsh to me.
Good luck
Exotexs
I agree that KYB are harsh, and so are Bilsteins, let's face it, marshmallows they are not. Great for race cars, though, but not for a Jaguar's ride.
I have found that cheap shocks last the same as expensive shocks. A Gabriel or Monroe or any "house" shock works just as well on a Jaguar, so save your money, don't waste it on expensive shocks.
Just my $2. worth.
Ex
Keoke
Yep EX, I go along with that reasoning too. I put Bilsteins in my Jag and it became noisy and rough as a cob.Upon investigation the so called after market shocks from Jaguar dealers in the plain white box are the same as the ones in the Green Jaguar logoed box and are priced about the same as other aftermarket brands.--Fwiw--Keoke
Keoke
Exotexs said:
Keo,
I haven't tried SPAX, but they are soo expensive.
Yes recently I have not heard too much about Spax or Konis ether. I think both of them kinda got out side the range of peoples pocket book.
Ex
Exotexs
Shocks are a subject that really makes my blood boil. :smile:)
what I do is buy the cheapest shock on the day I'm buying, then change them more often so I always have a like-new ride. New shocks have a good amount of resistance, no matter what brand, it's after 3k miles when you notice that they start melting and become like marshmallows. I've had some real cheapies that outlasted expensive shocks I've used in the past since my first car in 1969.
If I remember correctly, they were from J. C. Whitney for heaven's sake.
This was back in 1974-75 when I had both a 1971 Volvo 1800-E Coupe and a 1973
1800-ES Sportwagon. I miss those Volvos, they were fine cars.
Just bring one of yours to your local parts store (AutoZone, NAPA, CarQuest, PepBoys, etc.), and tell them to match it. Don't tell them it's for a Jaguar, tell them it's for "a chassis you are building"! Otherwise they nail ya. Stick to your guns or walk away from computer-dependent parts "specialists" who can't find a part unless the computer tells them a part number.
Shocks are shocks are shocks. I don't need no nitrogen nor helium, I tried it but I didn't inhale it... I have no brand loyalties. My only loyalty is to my cars. Here's my list of brands to Stay Away From on the simple premise that they are over-rated and over-priced:
1) KYB (harsh, like granite, they will destroy your bushings)
2) Koni (harsh like a Kryptonite meteorite from space, even in their "Soft" setting, better buy new bushings too).
3) Bilstein (they leak, they are not suited for Jaguar, they are not designed for Jaguar, they are harsh too until they start to melt and leak). (Personal experience).
4) Boge (a copy of a Gabriel in disguise and priced like a KYB, buy the Gabriel and save the headache).
5) SPAX (only on the basis of price per shock, otherwise I've not tried them, but to be fair, I hear they are very good shocks, not hard, so you spend the money and then you tell me about your experience with SPAX shocks, I'll be waitin'.
Well I sure hope I didn't put anybody to sleep!
Ex
Brill
Member
Is the conversion as easy as simply replacing the hydro shocks with regular shocks and capping off the fluid lines?
I know some of the kits come with new springs but from what I have heard, most of those spring kits end up giving a bit of a harsh ride.
If the "kit" is no more than a couple of standard shocks and a couple of bleeder valves, I'll source everything on my own and save a bunch of $$ I would imagine.
I can easily flare the lines and install bleeders.
Thanx!!
Talk soon,
S TR2/3/3A the self of POR15 is and how to apply POR15 Triumph 11
B TR4/4A Self locking bolts question Triumph 13
G Self build Healey, TR or MG Austin Healey 2
PC DIY tips from Bo his self Other Cars 0
glemon TR5/TR250 Steering Self Center Triumph 4
Michael Oritt Trafficator stopped self-cancelling Austin Healey 19
GTP1960 TR2/3/3A Self canceling turn signal, "hit or miss" Triumph 1
catfood Self tapping screws an rust prevention Austin Healey 10
JPSmit Note to self Restoration & Tools 6
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
S Clutch self-adjust? Austin Healey 28
NutmegCT A completely self-centered post Triumph 13
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
M Self Dimming Mirror on 99 XJ8 Jaguar 1
JPSmit Interesting drive home and note to self. Restoration & Tools 0
livinginthepast self-delete | sorry, i screwed up. Spridgets 1
JPSmit Note to self - next time get a BE Spridgets 3
Brosky Self healing vacuum leak??? Triumph 6
Jim_Gruber Note To Self - How to start your Spridget on fire. Spridgets 11
19_again self dimming mirrors MG 15
roofman Self inflicted wound, need some help Triumph 18
G Add "Blog Roll Call" to AAW -- U Might Find Y'Self Triumph 11
G Shameless self promotion Triumph 1
G TR5/TR250 TR250 do it your self alignment Triumph 5
Bret Shameless MG owner self-promotion. MG 3
bighly Self disintegration of Moss supplied rotor Austin Healey 18
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
CARSINC Sprite Electrical System Information Spridgets 2
S TR2/3/3A Lockheed brake system Triumph 7
B Stainless Steel Exhaust System Wanted Austin Healey 5
T TR2/3/3A Brake system question - Triumph 4
T TR2/3/3A Help - Cooling system problem Triumph 7
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
R TR2/3/3A Windshield Wiper System Triumph 2
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
C MGA Change a pull starter to a push button system MG 6
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
R TR6 Evaporative loss system modification Triumph 5
steveg TR6 Cooling system filling Triumph 7
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
jfarris TR2/3/3A Split Braking System Triumph 8
W Electrics, fuel system, under bonnet temp. Austin Healey 3
C Ghost in the electrical system Austin Healey 51
B A/H 3000 braking system Austin Healey 2
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
D Trying to understand my cooling system Austin Healey 29
S Side exhaust system for BJ8 Austin Healey 16
