roofman
I am installing a new dash panel in my 72 TR6. All electrics worked fine before I took it apart.I added a new ignition switch, new turn signal assembly in steering column, and a new hazard switch.
Now I have no temp guage, turn signals, erratic hazards, and keep blowing a fuse ( second from the top in panel ).
I have Dan Masters book and am quite sure that the hazard and turn signal switch is wired right.
My qustions are:
1. Tach is out. Do the tach lights complete a ground when installed to the tach that could cause problems, like on the tail lights?
2. Turn signal switch from TRF has 3 wires. One is different color than original lucas. I hooked the same color wires up as shown, and the odd one to the left over connection. Does this seem right?
3. Can seat belt buzzer have any thing to do with my problem? Seat belt wires have long ago been disconnected, but I have no way of testing buzzer still installed.
Thanks in advance for your help.
My qustions are:
