TR5/TR250 TR250 do it your self alignment
gjh2007
The PO of my 250 rebuilt the front end & the thing pulls hard to the right & seem to scrub on a sharp turn. Has anyone done the string method to get their alignment (toe in only) close for some light travelling?
Any info would be appreciated.
piman
Hello Gary,
The following is second hand advice and I have not actually tried it.
Set the car to straight ahead on the steering, then put a magazine in front of the front wheels. Drive or push the car over the magazines, and if the tracking is out then the magazines will twist as the tyre runs over them. Adjust the tracking to compensate and try again until the magazine(s) do not twist.
This principle is used on at least one commercial tracking gauge sold here in the UK.
However, the cause of the pull is unlikely to be due to a mistracked steering. (I take it that it hasn't got power steering and the rack is off centre?) I would look carefully at the front suspension comparing one side to the other.
Alec
Eric
Note: Only use magazines devoted to riced up Hondas. Using back issues of Classic Car will cause the Prince of Darkness to darn you to heck, as they say in Dilbert. /ubbthreads/images/graemlins/grin.gif
Dave Russell
Yoda - R.I.P
[ QUOTE ]
Hello Gary,
Alec
[/ QUOTE ]
Forty years ago, several shops in my area had this type of gage built into the shop floor. As customers drove over the gage the mechanic would note the tracking & often sell the customer a front end alignment job. Don't know if they are still doing it.
MDCanaday
Gary, It sounds to me like a camber problem. Get a cheap carpenters level and check each wheel. If you find either wheel is off the "bubble" more than the other, it's trouble, likely a prior accident poorly fixed.
In a front end alignment a vehicle will allways pull to the POSITIVE camber side, therefore if the cross camber is over 1/2 deg its bad.
With the IRS , you will need to have thrust checked too, find the best front end man you can in your area. Its a job for a pro.
MD(mad dog)
MGTF1250Dave
Aloha Gary,
I've used the string method on my MG and TR3. I'm assuming that you are referring to stretching a string from the rear of the car to the front along the tires and sighting down the string to see if it is straight. I've found that it is quicker to use a string on both sides. If you make an adjustment to toe in, roll the car forward a bit and recheck. The flexing of radial tires when you make adjustments can sometimes give a false reading, moving the car allows them to relax so to speak. I gotten good results in adjusting toe in with this method. This method doesn't allow for any check of chamber and castor however. Since my cars have no adjustments for these, any problems are from perished suspension parts.
Safety Fast,
Dave
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
B TR5/TR250 Registry for TR250's? Triumph 1
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
RobT For Sale Triumph TR250 - $32K Triumph Classifieds 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
T TR5/TR250 Original TR250 sun visors Triumph 0
Marvin Gruber TR5/TR250 TR250 Alternator Triumph 13
glemon TR5/TR250 TR250 Prototype Triumph 10
flylear45 TR5/TR250 TR250 resto project log Triumph 12
M TR5/TR250 No spark on TR250 Triumph 17
David Townsend TR5/TR250 New TR250 Limited Edition Print Triumph 0
H TR5/TR250 TR250 rebuild question Triumph 3
