A panhard rod locates the rear axle under the car. It keeps the axle centered under the body. I may get one for my car, but I'm going to wait and see how the car handles after I rebuild the suspension with poly bushings first. The springs for the rear perform a couple of functions: 1) Normal suspension functions of allowing the axle to travel up and down, 2) locate the axle under the car. Because the springs at the rear of the car also locate the axle they are subject to all of the forces of driving (not just bumps). When you go around turns, the body pushes to the outside of the turn, but the tires try to hold the car on the line. As a result the rear springs and bushings "give" a little to the sides, causing the axle to become un-centered.
Normally, it's not a problem, with stock sized wheels and tires. When you increase the width of the tire you decrease the amount of clearance in the wheel well. So, the shifting over the axle could cause the tire or worse the rim to rub the fenders or inner wheel well wall.
However, on cars like mine with worn out bushings you can literally feel the back of the car shift over the axle. Smooth turns it's unnoticeable. It's those bumpy turns or turns with dips that i really feel the rear of my car shift. It almost feels like the rear is breaking loose only there's none of the tire squeal. Some of that can be attributed to the 70 series tires on my car, but I know a good portion of it is the suspension (I've seen the rub marks on the inner walls).
Anyways, panhard rods keep the axle centered like I mentioned before. I've only been able to find one kit on the net:
https://www.mgbmga.com/tech/mgb15.htm
I've asked about Panhard rods on these boards before:
https://www.britishcarforum.com/ubbthread...true#Post105550
I believe Aeronca mentioned making one of his own, but there were no details on how he did it. However, from looking at the kit that's available there doesn't seem to be a whole lot to the design. I'll probably buy the kit if I find I need one, though.
