Headlight Rim Fasteners
healeygal
The chrome headlight rims on my Healey have the head of some kind of round brass fastener on the top (no slot, so it's not screwed in). I've seen headlight rims on other Hundreds that don't have this item - what is it for?
Sharon
BN1
Dave Russell
Yoda - R.I.P
Hi Sharon,
Original rims had a rivet on top that secured a flat tab inside to mate with a slot in the top of the headlight rear mounting ring. This holds the rim securely at the top. There is a hole in the bottom of the rim for a sheetmetal screw that goes into a retaining clip. Your rivet has likely gotten it's chrome or nickel polished off over the years.
Most replacement rims just have a raised bump at the top with no internal tab. They rely on the turned down portion of the rim to catch on the rear mounting ring edge. Really, kind of an inferior substitute but much easier & cheaper to find.
Geo Hahn
TRs have the same rivet... I never thought about it but I suppose it could have had a plating on it back when. At least brass polishes up real nice and as noted -- designates an original part.
H
healeygal
[ QUOTE ]
[/ QUOTE ]
Cool! /ubbthreads/images/graemlins/savewave.gif
Sharon
BN1 /ubbthreads/images/graemlins/savewave.gif
P TR6 ^%$#headlight rim Triumph 4
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
K TR4/4A 4A chrome headlight rim installation? Triumph 2
G TR2/3/3A Headlight Rim Triumph 7
A TR2/3/3A Hilarious TR-3A headlight rim story Triumph 2
Rut Bugeye headlight rim attachment part Spridgets 18
I TR6 rivets/bracket source for TR6 headlight rim? Triumph 5
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
S Replacement Headlight Switch Spridgets 4
jaegzie Headlight buckets Spridgets 3
