Replacing back of the boot and two bottom corners
JOeyKnapp
Hmm..
I am not sure how I will get in to weld the seam of the rear trunk piece and the bottom corner repair pieces (they form the visible seam at the bottom of each rear fender).
I haven't cut the replacement part out yet to see what the factory did, because I ordered the wrong part and am waiting on them to come in.
Any advice?
nomad
On my 65 I got rid of the rust pocket and welded a piece straight from the trunk deck to the outer fender. The factory wanted to spot weld everything and end up with a smooth outer surface which is why they did as they did. We don't need to worry about that since we will be using a little filler to smooth things up anyway.
Kurt.
J
JOeyKnapp
I am trying to keep at least the body as original as possible, I don't want to ruin my cash cow when the market turns on these things and they become gold! :smile:
I was looking at it a little more tonite. It looks like the seam is welded from the outside and brazed at the top. I am thinking about using some body sealer/epoxy on the seam inbetween the top and bottom to glue it together. Plenty of new cars use this technique.. (of course, leaving the gap on the outside, I like the gap!)
J
JOeyKnapp
So, now my plan includes replacing the inner and outer bottom pieces. I have the passenger side inner part out and will get the driver's side next. I am thinking that once both of those are out (and pending my floor repair solution) that I will install the back middle piece and then cut out the outer bottom pieces that need to be replaced. That will give me access to the seam so I can weld it.
I was a little disappointed with the outer repair pieces, I was hoping that they would extend to the seam and include the top foldover piece that is the bottom of the taillight area. It's more like a slightly curved patch panel. I will end up leaving the factory metal on the outside of the seam, and buttwelding the panel in.
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
B TR6 replacing U joints Triumph 0
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
