Jim_Gruber
How do I remove the aluminum channel on top of the door on a Mark IV Sprite, Mark 3 Midget. I found the two 5/16 nuts and can get it to move back and forth easily but dont know if those nuts on the inside of the top of the door need to come off to remove this piece of not. Looks to be a total PITA to get nuts back on if I do need to remove. Another case of children or MOWOGs needed to reassemble. I'm replacing the vinyl on top of the door as it is ripped and need to feed the end of the vinyl under that aluminum plate. Heading to the store for some contact adhesive and hopefully an answer will be here when I return. TIA.
