Rear main Scroll Seal
MrAlex
Member
I'm in the process of engine reassembly on my 4. I have a question for those possibly knowledgeable on the subject on the rear Scroll seal. Despite recommendation to go to the newer style seal I decided to keep it as is since my crank was in no need of a grind on the journals..knowing it will leak somewhat as original. My question is: why can't I loose fit the new scroll seal halves on the block and rear bearing cap and then use the crank w/ main bearings in place and tightened to align the scroll seals? Instead of using the " $50 alignment Tool"? It seems to me this would be a better way to align the seals. Also, Q#2: the Bentley manual says to use "Jointing compound on the contacting faces" - Does this mean the contacting faces of the Seal Halves? or on the faces of the halves to the Block and Bearing Cap? Thanks for any advice.
TR3driver
Great Pumpkin - R.I.P
Because the crank won't be centered in it's running clearance, and there won't be any clearance between the seal and crank. As soon as you start the engine, the crank will tear into the seal, likely ruining both of them.
Actually, it can be done, by adding shims to correct those two problems. An old time TR3 racer once told me he did it using sewing thread wrapped around both the main journal and the scroll; but I've not tried it myself.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Instead of using the " $50 alignment Tool"?[/QUOTE]From what I've been told by those who should know, the "$50 alignment tool" is worthless and results in too much clearance. Supposedly even the dimensions given in the shop manual are too big, and the tool is bigger yet.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Also, Q#2: the Bentley manual says to use "Jointing compound on the contacting faces" - Does this mean the contacting faces of the Seal Halves? or on the faces of the halves to the Block and Bearing Cap?[/QUOTE]In a word, Yes. Both places.
M
MrAlex
Member
Thanks for the reply. Since I am going with the Scroll.. it seems I need to provide an adequate clearance gap. I was thinking a layer of grease (assembly or molly lube) or even a layer of teflon tape might provide adequate clearance rather than thread which I think would be inconsistent in the scroll threads. What other options or alternatives have others used for this?
martx-5
I borrowed one of those alignment tools from one of the guys in the Triumph club, and is WAS about .003"-.004" larger then the dimensions in the factory manual. My original seals showed no signs of any leakage. Fortunately, I hadn't yet removed them from the block and cap so I was able to take a measurement. Sure enough, as Randall has said, it was a couple of thou smaller then the measurement in the book. I made up a tool with this new measurement. I'll only know how well it worked after I fire the engine up, which won't be for another month or two.
M
MrAlex
Member
Hi Art.. Would you be interested in Renting out your tool to me? I'm up in Poughkeepsie. Funny.. also my wife will be in Glen Cove today at a Baby Shower if it is possible to arrange something please let me know. Also, if you have the dimentions another option would be to have a friend turn one for me on his lathe. Alex (cell 845-464-0505)
TR3driver
Ah, here it is. One message says the seal clearance (to the scroll on the crank) should be .003" (implying you should measure your crank and make the mandrel .006" larger in that area).
Another says the mandrel should be 2.818" where the workshop manual shows 2.822".
martx-5
I talked to Alex by phone and would have loaned him the tool I made up, but unfortunately, I loaned it to another club member and he can't seem to find it at the moment...whatever that means. The tool I made measured about 2.8185". I just used a piece of delrin we had at work. No handle...not neccessary. Besides, I had the engine on a stand and the handle would only get in the way. The ones from Moss are made from some sort of hard plastic, but as mentioned above, are oversize.
Tim Tucker
Interesting. I made mine back in '82 to 2.819" (I am ashamed to admit I was aiming for 2.822"). I missed the scroll diameter by -3 mil and the hit the crank diameter. Blind Luck..:smile: I used it to put my TR4's main seal in and it doesn't leak any noticeable amount...:smile: Wish my TR6 had the same problem.
Tim
M
MrAlex
Member
I am going to try an experiment by using 1 layer of Teflon Tape (which I measured to be 0.003 in.) on the Crank Scroll with the Scroll seal halves fit loosely and with sealing compound only on the faces of the seals. Then torque down the crank with bearings in place and align/tighten the seal bolts. Then remove the teflon tape.
TR3driver
What are you doing to center the crank in it's bearing clearance ?
M
MrAlex
Member
I have between 0.0015 and 0.0020 clearance on the rear main bearing using Plastiguage. That is with no Lube taking the measurement. I figured if I do the Rear seal fitting with Assembly Lube in place on the Main Bearing it will take up a portion of the gap. Worst case witht the motor right side up I'll still have clearance on the bottom side. I guess that I could even take some of the gravity weight off the crank to do the seal as well. Tell me if you think I'm nutz (maybe you already did).
TR3driver
Personally, I'd still follow Hardy's advice and wrap the crank journal with thread while setting the seal. I don't think your assembly lube is anywhere near thick enough to carry the weight of the crank without squeezing out. But that's just me, perhaps your method will work fine.
(Actually, I got talked into converting to the lip seal, so I won't have to worry about this particular step
S TR2/3/3A rear main seal is leaking Triumph 13
Drone Dog rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General TR Rear Main Seal--Minor Problem Triumph 4
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
Gerard 1098 "10CC" rear main Spridgets 0
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 9
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
KVH TR4/4A Viton Rear Main Seal Triumph 12
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
S TR2/3/3A tr3 rear main Triumph 24
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
B Rear main seal kit Spridgets 3
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
P how to replace rear main seal in 1500 midget Spridgets 2
TraceZ rear main leaks Spridgets 3
R Rear main seal question. Spridgets 29
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
KVH TR4/4A Rear Main Seal TR4A Triumph 17
B 1970 XKE 4.2 rear main seal Jaguar 2
B rear main Spridgets 5
B rear main puller Austin Healey 6
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
58Custom 1275 Rear Main Seal Kit- - seek info Spridgets 2
glemon Rear engine main seal review Triumph 7
J Moss rear main seal. Austin Healey 5
TimK Rear Main Seal Kit Installation Austin Healey 24
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
V TR6 TR6 Rear Main Seal Triumph 17
jlaird Installing the rear main cap cover correctly: Spridgets 3
aaronclark TR2/3/3A TR3 Rear Main Seal Questions Triumph 7
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
spartan0199 rear main seal kit 833-145 Austin Healey 12
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
fad64b TR2/3/3A Rear main seal TR3 Triumph 12
S TR2/3/3A tr3 rear main seal Triumph 6
A TR6 TR6, Best front and rear main seal ??? Triumph 0
M TR2/3/3A TR3 Rear Main Upgrade Triumph 6
