rear main seal kit 833-145
spartan0199
Member
Hi (also sent to Healey email list...)
I emailed the list back in the fall about a problem I had with my clutch. Since that time I've taken out the gearbox and the clutch disk shows signs of oil contamination. A couple of days ago I just ordered parts from Moss, one being the rear main seal kit 833-145. When I got my order confirmation this part was not listed (no backorder, just said "0"). So I just gave them a call and they told me they are having technical difficulty with this part and it is no longer available (yikes!). They said it might be available again in the future but no timing on that right now. Long story short, it is starting to get nice in Michigan and I'd like to see if I can get this car back on the road. Are there any other vendors I can get this part from and be confident it will work?? Anybody with good experiences please let me know.
Thanks,
Justin
1961 3000 BT7
Dave Russell
Yoda - R.I.P
I believe BCS has the DWR style rear seal, not the same as the Moss seal:
https://www.britishcarspecialists.com/
You can see the seal here:
https://www.bighealey.co.uk/section.php?id=4&page=4
Usually rear main leakage is diverted from the clutch by the flywheel. If the drain is open in the bottom of the flywheel housing, any leakage usually drains out without getting into the clutch.
Leakage from the front of the transmission is another matter & if bad enough, could soak the clutch.
Keoke
Well Spartan0199, seeing's how you are close to MD. I think Healey Surgeons can supply you with a rear engine seal Kit.--Fwiw--Keoke
B
BobHorvath
Justin
Did they say what the problem was with the seal? I just bought one in Stockton from British Car Specialists 209 948 1030 and installed it. I agree with Daves remarks as I had a bunch of oil comming from the crank. Since the gear box was low on oil and since the car was new to me, I also installed a front gearbox seal. I had a ton of oil comming from the crank, through the vent Dave refrenced. The point of all this is that the crank oil leak (big as it was) had no effect on the clutch surface. My guess is that the gearbox seal might be causing your clutch problems. Installing the crank seal is interesting. I suggest you drill&tap into the block and bearing cap deeper than the 10mm suggested. I had to machine down the bolts or could have used a bottom tap for enough thread travel to pull-up the seal houseing tight enough to the block.
healeynut
Justin - Steve Norton at Cape International will have this seal too.
healeylvr57
there is a kit selling on ebay for $80
Item number: 230108160390 has anyone heard of or used it
seems abit on the low side compared to others
Keoke
I can not Identify the source vendor for that seal on E-bay from the picture and it does not include a "Buy Now Price". However, the seller is a well known Healey restoration / parts supplier here in the US.---Keoke
spartan0199
spartan0199
Member
The person at Moss I spoke to didn't offer much detail as to why they aren't selling this kit anymore, just that there are "technical problems" with the part. I plan to also change the seal at the front of the gearbox.
Justin
spartan, one difference between the dennis welch seal and the others is that a bit more material from the engine back plate must be removed for the d.w. one to fit. otherwise there much the same./bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
Dave Russell
Yoda - R.I.P
While we are on the subject of seals, my early side shift gearbox, BN2, 4 speed, does not have a front seal. Does anyone know of a front seal conversion for this gearbox? Thanks,
Keoke
Hi Dave, I do not know the source of the seal. But someone has that front assembly either recast or remachined to take a seal. Maybe some others on the forum have installed one. There was an article in one of the Healey Magazines several years ago showing the new part and defining its source or method of modification. You might give Knock a call he may know how it is achieved.---Fwiw--Keoke-?
S TR2/3/3A rear main seal is leaking Triumph 13
Drone Dog rear main seal Austin Healey 13
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
KVH General TR Rear Main Seal--Minor Problem Triumph 4
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 9
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
KVH TR4/4A Viton Rear Main Seal Triumph 12
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
B Rear main seal kit Spridgets 3
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
P how to replace rear main seal in 1500 midget Spridgets 2
R Rear main seal question. Spridgets 29
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
KVH TR4/4A Rear Main Seal TR4A Triumph 17
B 1970 XKE 4.2 rear main seal Jaguar 2
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
58Custom 1275 Rear Main Seal Kit- - seek info Spridgets 2
glemon Rear engine main seal review Triumph 7
J Moss rear main seal. Austin Healey 5
TimK Rear Main Seal Kit Installation Austin Healey 24
M Rear main Scroll Seal Triumph 11
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
V TR6 TR6 Rear Main Seal Triumph 17
aaronclark TR2/3/3A TR3 Rear Main Seal Questions Triumph 7
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
fad64b TR2/3/3A Rear main seal TR3 Triumph 12
S TR2/3/3A tr3 rear main seal Triumph 6
A TR6 TR6, Best front and rear main seal ??? Triumph 0
C rear main oil seal Austin Healey 4
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
Gerard 1098 "10CC" rear main Spridgets 0
S TR2/3/3A tr3 rear main Triumph 24
TraceZ rear main leaks Spridgets 3
B rear main Spridgets 5
B rear main puller Austin Healey 6
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
jlaird Installing the rear main cap cover correctly: Spridgets 3
