tahoe healey
Spent the day doing the clutch and brake master cylinders. Clutch is fine in fact better then ever. The brake catches well but on the next pump catches sooner. Probably needs re-bleeding as air may have entered the system. My question is where would the best place to bleed? I had a leak at the right front wheel so I'm thinking there as appose to the master cylinder.
This was a bitch of a job with out a lift. Not looking forward to a do over.
