bleeding de brakes
ramajon
Member
i have 2 manuals w/ differing procedures...1 says to loosen both front and rear adjustments and then bleed and adjust...the other says to lock down the rear and open the front then bleed and adjust...my logic says adjust then blead and then check adjustment...any useful tips would help...i am installing a lockeed remote brake servo and braided hoses...then the bleed
shorn
I have always bled starting with the bleeder farthest away from the reservoir according to the length of the brake line and work toward the reservoir. For my BJ8 that would be the rear left, then rear right, then front right, and front left. Isn't the the rear left closer to the reservoir than the rear right? NO, not according to the way the brake line is run.
John Loftus
I do the same thing and go around at least one more time to make sure all the air is out. Don't forget to bleed the clutch too if you are bleeding to replace oil fluid or had the reservoir off for the rebuild. I use the EZbleed system which makes the job and "EZ" one person operation.
Cheers,
John
Keoke
Hi Ramajon, Any of those procdures you have will work. Your #1,is a more complex technique and requires considerably more fluid. Use the techniques provided by others here and you will be good to go.---Keoke-AZ- /ubbthreads/images/graemlins/cowboy.gif
Somewhat related:
Does anyone use Speed Bleeders on their cars? Are they useful in making this job easier and/or worth the cost? WOuld they be particularly useful for bleeding the Clutch?
I'm kind of thinking of getting a set, but some information about others' experiences would be useful....
Dave Richards
If those work as good as the thinking, they'd be cool to have!
GregW
Platinum
Hi James,
I have six speed bleeders on my car. I’ve only bled the system once and that was right after filling an empty system. They didn’t seem to work as advertised. I would up bleeding them the next day in the traditional way with someone pumping the brake pedal. The second day, a lot of bubbles were still coming out.
R
ramajon
Member
got everything all plumbed in and bled..the brakes are definately better but i still have a very long pedal stroke...any way of adjusting the pedal stroke???
GregW
Platinum
Hi Ramajon,
You mentioned installing a booster. Was there one in the car before? You may want to change your master cylinder to a wider bore if the booster is new to the car and you haven’t done so. That will shorten the stroke some. Then of coarse, you’ll need to bleed the brakes again.
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
C TR2/3/3A bleeding brakes Triumph 11
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Jim_Gruber Brakes and Bleeding Spridgets 16
oxford Bleeding Brakes! Up-date. Austin Healey 0
oxford Bleeding Brakes! Austin Healey 25
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
T Spitfire Bleeding brakes Triumph 6
B Bleeding BJ7 brakes Austin Healey 9
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
tahoe healey Bleeding the bloody brakes again Austin Healey 10
tahoe healey re bleeding brakes. Austin Healey 5
pkmh Bleeding brakes Austin Healey 18
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
bcbug Bleeding Brakes Spridgets 2
drooartz Help -- first time bleeding of clutch/brakes Spridgets 8
chicken bleeding the brakes Austin Healey 9
bighealeysource bleeding the brakes on my BN1 Austin Healey 4
bighealeysource bleeding the brakes on a BN1 Austin Healey 15
WillR bleeding brakes MG 18
C What was that tool for bleeding the brakes? Spridgets 3
RickB Bleeding dual circuit brakes? Spridgets 12
SCguy Bleeding Brakes ? Triumph 10
O TR6 Bleeding TR6 Brakes Triumph 2
jlaird Bleeding brakes Spridgets 8
Monark192 Bleeding Brakes MG 12
delisaj Bleeding the brakes-- won't work.. help! Triumph 4
SCguy TR4/4A Still bleeding my brakes on my TR4!!! Triumph 7
Guinn Bleeding brakes MG 9
SCguy Bleeding Brakes tips? Triumph 7
B Help Bleeding the Brakes Austin Healey 13
R tool for bleeding brakes? Rover / Land Rover 3
F Bleeding Front brakes MG 11
S Bleeding the Brakes Austin Healey 10
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
N Need brake bleeding advice Spridgets 6
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
F TR2/3/3A Bleeding Technique Triumph 46
K Bloody "bleeding" issue Austin Healey 55
bugedd Bleeding clutch Spridgets 2
F TR2/3/3A Bleeding Hydraulics Triumph 9
S Help with clutch bleeding on BJ8 Austin Healey 7
