memphis
Hello!
When I turn on my panel lights there is no light on the fuel gauge and the tach. Other gauges light up nicely and the red ignition light on the tach works.
There is a light attached "externally" on the fuel gauge holding bracket (bulb positioned in upper left corner?) that does work, but this only lights up and shows the gap between the edge of the dash pad and the wood dash panel. Maybe this is in the wrong position?
Should there be an internal light in the fuel and tach gauge? If yes, are these easy to replace?
New to Healey and British cars so really appreciate the help and advice!
Thanks!
Bob
Thanks!
Bob
