Overdrive Help 3 & 4 Gear selector switch faulty?
Andrew1
Hi Gang and thank you so much for all your help! I tried to add my two cents on a solution for removing ceased A-arm bushings... I know a sawsall sounds drastic, but it worked well and I added it the recent bushing posting if you are interested.
Onto the next issue. The overdrive on a BJ8 has been overhauled mechanically, and I've experienced intermitant shifting in and out of overdrive at highway speeds in third gear only. Fourth gear overdirve operation is fine.
Further diagnostics revealed that the Solinoid was bouncing in an out of activation by slight movements in the normal play of 3rd gear. It appears that the switch that "detects" 3 & 4th may be faulty or misadjusted.
Actually it's sorta cool operating the Overdrive with slight flicks of the gearshift..... like a 60's version of Tiptronic!!!
Before I take off the transmission cover for the 10th time this season and for potential part ordering efficiency I'd like to get the feedback or experiences of those that might have had similar issues, specifcally;
1) Can the existing switch be adjusted?
2) If it has to be replaced, what is the Moss part number (the illustrations descriptions are not very clear in their catalogue)?
Thanks again as always!
- Andrew -
Keoke
HI Andrew, Yes the OVD switch on the gear box gear lever extension is adjustable.So is the Throttle sw. Be sure the throttle sw remains closed for~ 20% of the gas pedal travel.Also look at the OVD sw on the gear lever extension.If it has been improperly set up it is possible that the anvil it rides on has damaged the aluminum housing which traps the ball actuator in the switch barrel.There are two SW types: 1} has screw terminals Part No;141-100 and 2} Has Lucar terminals Part No;140-470, Additionally you may need the SW adjusting washer Part # 324-145---Fwiw---Keoke
Dave Russell
Yoda - R.I.P
Re: Overdrive Help 3 & 4 Gear selector switch fau
Hi Andrew,
I agree with Keoke. The most likely problem is that the 3-4 switch is not set quite close enough to the internal shifter mechanism. The adjustment involves setting the switch a bit closer (screwed in deeper) by using a thinner washer between the gearbox case & the switch. Almost any washer or combination will work.
I would start with something about .020" thinner than the existing one. It's pretty easy to check continuity across the switch terminals (wires removed) & adjust the washer thickness as required to get positive switch closing with the lever in the 3 & 4 position. Don't move the switch any closer than just enough to make the switch work.
vette
Hi Andrew, It could well be an electrcal issue with the O/D as the previous contributors have talked about. They do have alot of experience. But my O/D also drops out once in a while, while cruising in high gear, at lower speeds, with light throttle. It has been suggested to me (on this forum as well) to check the transmission oil level, and to clean the strainer screen mounted in the O/D unit. My oil has maintained good level, but I have not cleaned the strainer as yet. Just thought it might be something else to check.
/ubbthreads/images/graemlins/cheers.gif Dave.
Dave Russell
Yoda - R.I.P
Hi Vette,
Since the OD pump is operated from the OD tailshaft, & it is turning relative slowly at lower speeds, dropping out would be a sign of low oil pressure in the OD. Provided that the OD solenoid is not dropping out. There could be many reasons for this. Your suggestions are a good place to start. Using a slightly higher viscosity oil might help if the oil pump or the accumulator is worn. Check first to see if the OD solenoid is staying put. Transmission cover removed. Don't get your shirt tail caught in the propellor shaft. This will tell you if it is an electrical or hydraulic problem.
golf
Member
Hi Andrew,I experienced the exact symptoms.However all of my attempts to adjust the switch you mentioned did not totally stop the problem.I have a habit of holding on to the gear shift while driving and found that I could shift in and out of overdrive with the slightest movement of the gear knob.I finally gave up and ordered the switch#140-470 from Moss.Now the overdrive stays in.This is a very important switch to guard against damage to your overdrive while backing up,so always make sure it works properly.Good luck,Ben
vette
Thanks Dave, I do have to get around to cleaning the strainer and doing some diagnostics on this situation, but It has happened so very few times and I am enjoying the week-end outing so very much that I just keep driving it. I did repack my front wheel bearings last week though, and put another 200 miles on the Healey today. Just got back. I have some other project cars I'm working on for other people and 'my' cars just get the minimum maintenance to keep them going. Thanks for the help.
A
Andrew1
Andrew here and the problem has been fixed as per the feedback from Keoke and Dave. Thank you as well as the other contributors too!
There was two spacing washers installed and a quick removal of one washer plus a cleanup of the lucar terminal switch and the gear seletor anvil allowed the switch to close properly.
I noted too that the switch button had developed a slight pit from the years of use in the same spot, however I decided to simply spin the button 45 degrees and allow it to brush against the fresh metal..... if all thing go to plan I can keep rotating the switch button for another 60 years until I have to replace the switch ! haha
Giovanni59
Hi, I am not as technically knowledgable as you guys but I am experiencing a similar problem. I have a 1958 100-6. After driving at 60-70 mph for 5 to 10 minutes the overdrive starts turning off and then on. This happens when I am in 4 th gear. Is it an adjustment problem like you guys have been discussing?
Thanks
John
Dave Russell
Yoda - R.I.P
Hi John,
If wiggling the shifter has no effect on the problem it is not likely to be the switch. See my answer to Vette above re: oil pressure.
i also had intermitant operation of my overdrive,on and off as it pleased.i found that a wire on the "overdrive"dash switch was warn through just at the connecting point it was bouncing in and out of contact with the switch,removed switch-clean and reinstalled wire,result-less r,p,m's-more go!
M TR2/3/3A Overdrive help. Triumph 21
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
Simmo I need help with J Type Overdrive Triumph 15
bighealeysource Help -think I've got a bad overdrive solenoid ? Austin Healey 8
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
71tr Need help with overdrive removal Triumph 7
KLUTZ Confused with my Overdrive wiring.. Help please MG 3
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
AUSMHLY Help with tranny overdrive leaking Austin Healey 3
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
Bob Claffie Overdrive help Austin Healey 4
jaybird HELP! Overdrive on ebay... MG 17
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
