Setting this adjuster doesn't increase the oil pressure. This is the setting where (if the oil is cold as Bill noted above), the bypass, loaded by the spring setting, will open and prevent the oil pressure from going higher than 70 psi. If the bearing clearances in your engine are worn, and you never get more than, say 50 psi, then the adjustment will never function.
