TR4/4A Once head is off how do I...?
tdskip
I am dragging my feet on pulling the head as I am not sure how I am supposed to measure any liner protrusion accurately. Is there a specific tool I need to track down or borrow?
Thanks for the help!
TR4nut
Tom- a simple feeler gauge is your friend here. Just put something in top of the liner like a straight edge metal ruler and use a feeler gauge to measure the gap between the straight edge and the block. Measure at several locations. Easy job.
TomMull
The factory service manual has instructions too. Tom
J Problem with Head Gasket blowing more than once Triumph 10
T General Tech Once again, check the easy stuff Triumph 2
JPSmit It's only original once Spridgets 2
Z New forum participant - once I find a car! Austin Healey 61
pkmh Distributor rotor gone bad more than once. Austin Healey 5
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
RichBall OT Once in a Blue Moon Spridgets 3
SeldomSeen Spitfire Just Once in my Life, I'd Like to Drive a Spitfire Triumph 9
S TR2/3/3A TR-3 hard to start, but runs well once started Triumph 5
rick_ingram As Willie Nelson once sung..... MG 9
Bob Claffie Once in a lifetime Other British Cars 4
T Stromberg mixture how-to, once again. Triumph 38
S MGB "Once you've seen one MGB.............." MG 32
T TR4/4A Once more - with feeling - Tr4a front suspension Triumph 10
Hap Waldrop Computer wiz, once again pleeeeze Spridgets 14
Grantura_MKI TVR to start production once again? TVR 0
AH_3000 BJ 8 Toolkit - once and for all... Austin Healey 25
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
JPSmit once again wiring Spridgets 0
T Once more for the stupid guy? Triumph 12
Jim_Gruber Vroom, vroom sounds heard once again. Spridgets 3
T TR2/3/3A Once more with feeling, adjusting oil pressure TR3 Triumph 4
heliguy Boxing the TR IRS Diff [ once again ] Triumph 1
S RHD Alpine once owned by Dave Reina Sunbeam (Rootes) 0
zimmy Rustoleum......yes, once again...... Spridgets 42
Woodie once more into the breach ...er carbs Spridgets 15
F did anyone race '59 prefects? even once? Other British Cars 3
P Slight loss of brake assist until pumped once Triumph 4
Nunyas The Prince of Darkness stikes once more... MG 9
tahoe healey tires once again Austin Healey 2
V8Blazer Driving once again, but have a question... MG 12
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 1
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
