More Starting help Required
mylesw
Hello
Almost there now hopefully with getting the engine started. Have solved the fuel issue and have set the timing etc according to the workshop manual. When I turn the key the engine turns and fires once, then stops. As it stops a strange screeching sound can be heard coming from the bellhousing which I guess may be related to the clutch/starter or flywheel but we'll come to that problem later.
The carbs have been rebuilt professionally and are HS6's. I am figuring that the problem may lie here but I don't want to touch anything unless I make it worse. All the manuals I have talk about how to tune the carbs once they're running. So question is - what should I start to fiddle with first?
Thanks for your help.
Myles
Geo Hahn
mylesw said:
...As it stops a strange screeching sound can be heard coming from the bellhousing...
I think I'd want to know the source of that before going much farther.
You might double-check the timing as it is not difficult to get it 180* off, which could give you some strange results (i.e. are you sure it is 'firing' and not 'backfiring'?).
I assume the engine turned freely when the plugs were out.
TR3driver
Great Pumpkin - R.I.P
I'm guessing that your starter bearings are dry, and what you are hearing is them squalling when the starter starts spinning at high speed after the Bendix kicks out. Probably a good idea to pull the starter and lube it's bearings; but of course that won't solve the Bendix kicking out.
Generally that is caused by one cylinder firing and the others don't pick up at the same time. Sometimes just trying again a few times (backing off the key each time and waiting for the starter to quit spinning each time) will do; but it seems to me that either more or less choke usually helps as well. You might also check that your chokes are reasonably well synchronized (ie both jets move by roughly the same amount with the knob locked out).
In extreme cases, a spray of carb cleaner down each carb throat may also help. It acts like starting ether, better than the "starting fluid" they sell these days. But don't go overboard with it, as it can also wash the oil off the cylinder walls.
M
mylesw
Engine started! Thanks for all you help with this. Couple of leaks in the cooling system that I need to address but otherwise looking okay.
Thanks
Myles
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
