Moisture in Rocker cover
mightymidget
I have been fighting the noise in what I belive to be valve train so I keep pulling off my rocker cover. I don't drive the car much. very short trips.
I noticed a sludge begining to build on the inside of rocker cover only. My oil dip stick doesn't show any signs of water in the oil.
I use to have a VX Bug that would do the same thing.
Is this normal? My rocker cover vent is open
scoutll
Sounds to me like that's exactly what it is. The top of the engine will collect the moisture gunk the most, because it is the last part to get hot enough to evaporate. It will normally accumulate more around and on the oil cap, and vent(s). The best way to avoid this is to make sure the car has the correct thermostat and gets up to operating temp when you take it out... This means more cruising and less short trips.... :driving:
K
KSIS
Yep. Chocolate milk syndrome. I used to see this when I had my Midget in Washington state. Short trips, not enough time for the engine to rach operating temp.
scoutll
Trips like that should get rid of it. Mine gets a little on the oil filler cap in the winter when I don't run it enough to get it good and warm.
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
drooartz Moisture barrier between door card and door? Restoration & Tools 7
bighealeysource How to control moisture/rust in a garage Restoration & Tools 5
Bill Redd Moisture in fuel tank Triumph 16
S Moisture in cylinder #3 - 850 - help? British Motor Corp 11
C Castrol LMA Lo Moisture Absorbsion and Natural Triumph 43
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
P Rocker Cover Vent Spridgets 22
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A rocker covers again Triumph 13
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
T TR2/3/3A TR Rocker Arm Spacers Triumph 7
Rut Which rocker assembly? Spridgets 7
B TR2/3/3A Questions about that rocker cover I "won" on E bay Triumph 6
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
