TR4/4A Material to make a mirror base gasket for door mirror install?
tdskip
Hi guys - what would you make a door mirror gasket to mount a door mirror on you door? Assuming not a material that absorbs water - grin.
trglory
My choice would be rubber. If you have an old inner-tube lying around, cut a chunk out of that and trim to fit. The thickness would be ideal.
Joe
Vila
I totally agree with the inner tube choice.
I keep an old inner tube under my work bench and have cut numerous pieces off for other such projects.
A blue pen works great for marking it and will make it approximately 1/16 inch larger than the mirror base for a nice look.
If you saw my old website, you can now visit my new and improved one at: https://jakegingervila.wix.com/bobs-vintage-cars-
Vila
1933 Chevrolet
1962 Triumph TR4
1984 BMW 633 CSi
S TR6 Soft top material Triumph 10
LAW75 Concours Reference Material Austin Healey 12
BoyRacer Blue Vinyl Dash Material Austin Healey 3
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
maxwedge5281 Side Curtain Felt Material Austin Healey 5
JimLaney hydraulic line material Spridgets 6
M Warwick Hardtop Headlining Material Spridgets 5
CJD TR2/3/3A Valve Material Triumph 7
J Brake line material Austin Healey 24
NutmegCT Source for rubber door seal material? Restoration & Tools 9
Schroeders Period Cloth Wiring Harness Loom Material Needed Austin Healey 5
I Door panel material Triumph 2
B door seal material an suppliers Austin Healey 2
I Best material for panels? Triumph 21
T what is best material for BE tops [and others]? Spridgets 1
A Material between front fender and tub Triumph 15
I Source for ribbed material for inside bugeye door? Spridgets 5
prb51 Fuel safe gasket material Triumph 5
dklawson Spitfire Spitfire Radiators - Does Size & Material Matter? Triumph 8
P Upholstery Material Spridgets 1
P SEAT COVERS and MATCHING MATERIAL? Spridgets 4
tahoe healey Interior door material Austin Healey 33
J Heat Shield Material / Carpet Dye? Austin Healey 15
histerical Reading Material Spridgets 2
Editor_Reid Asbestos Panel Replacement Material Austin Healey 10
Tinkerman Sound Deadning Material TR 2 and 3's Triumph 7
SpannerMan TR6 TR6 seat back webbing material source Triumph 7
dklawson Car Cover Material Question-Covercraft Ultra'Tect Triumph 6
regularman I think I found the perfect material Spridgets 5
N Which carpet material to use? Triumph 23
B BE Door Material Spridgets 16
tosoutherncars Soundproofing material? Spridgets 22
B MGB screen material for fresh air vent on mgb? MG 12
2wrench What sealer material to use top of windscreen? Triumph 12
71tr PDWA Valve O-Ring Material Triumph 6
H Door panel material MG 15
C material dashboard Austin Healey 1
71tr thrust washer material Triumph 7
racing girl Front Grille Material Restoration & Tools 10
J "body gasket" material Triumph 6
John Loftus Aluminum Shroud repair material Austin Healey 6
V Good sound deadening material Triumph 12
M Needed -- Red Plaid Material Triumph 4
T Original Material Top Replacement - '64 XKE Jaguar 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
K TR2/3/3A Wing mirror replacement again... Triumph 0
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
