Heat Shield Material / Carpet Dye?
jbmcohen
Member
Hello -
I have two separate questions:
1. I'd like to insulate my cabin. Does anyone recommend the Moss heat shield material or is Dynamat the way to go?
2. My carpet is in decent shape but it's faded. Has anyone dyed their carpet, instead of replacing it?
Thanks as always.
GregW
Platinum
jbmcohen said:
Hello -
I guess that depends on what you're after. If sound deadening is more important to you, I'd go with the more expensive Dynamat (that's what I did). If ease of installation and removal is important, a better choice would be the felt stuff.
I've never done that for a car, but dying isn't an exact science. You may not get the color you're expecting.
Keoke
jbmcohen said:
Hello -
-- :nonod: Use standard building insulation. If the walls are sealed it can be pumped in.
--- :nonod:-Cost, shrinkage and sometimes poor results makes replacement a better option. especially now. See if you can locate acceptable commercial grade pull ups at a dealer.---Keoke
Thanks as always.
GregW
Platinum
Keoke said:
jbmcohen said:
Hello -
:lol: What if he has a log cabin. Ain't no pumpin' then!
Keoke
Does not matter Greg, Either way open log walls or closed we can handle them. Actually a true chinked log cabin's wall closed on the inside is easier than a convetional wood stucco wall to do.-Keoke
TimK
Are you guys pulling legs? :nonono: I think jbmcohen is asking about his Healey!!!
JBM: Dave Russell, our dear departed resident wise man, has said in the past that we need to be careful what we recommend to people where affordability may be an issue. I just installed Heritage Karvel Carpet which comes with a nice thick felt (however, it cost about $800) but I also installed Dynamat Extreme which I got for $139. Dynamat is very easy to install but would be a bear to remove. However, I don't know why you would need to remove it.
GregW
Platinum
Hi Tim,
I thought I covered price vs. ease of removal in my first post. BTW, Dave went the really expensive route by putting two layers of dynamat on his floor and then painted it body color. I'm not sure if he painted underneath the dynamat, but knowing Dave, it's a good bet that he did. :wink:
Keoke
:nonono: not pullin his leg, now he can fix which ever one of em cabins he is talking about.---Keoke--
JBM: Dave Russell, our dear departed resident wise man, has said in the past that we need to be careful what we recommend to people where affordability may be an issue. I just installed Heritage Karvel Carpet which comes with a nice thick felt (however, it cost about $800)--WOT!!
-Didn't no body tell them there is a recession going on???
bighealeysource
Hey JBM,
The above is one of the pleasures of this forum - some of the comments
are hilarious ! Anyway, can't address the dynamat but have used a spray on
carpet dye before. Got one from Advanced Auto PArts made by Duplicolor
and if you have black carpets, pretty easy to use. Does leave the pile
a bit stiff but a lot cheaper and easier than buying new and replacing if
what you have is simply faded. Don't know about other colors. Good
luck.
Mike
TimK
Greg, yes, I should have singled out Keoke for my reprimand. And yes, I only knew Dave for less than a year, but he left a lasting impression. He was a first class guy with a very big heart.
Keoke
Now why you wanna pick on Keoke ? I thought he was using equivalent US speak and he had a"Cheeselog" he wanted to fix up.-Keoke--
TimK
Keoke, I appreciate all your knowledge and willingness to share with everyone. I've seen your posts all over the other forums as well. How did you come by all your knowledge?? What have you been doing all your life? I'd sure like to know more about all you folks who make this forum come alive. The stuff on your profiles are very slim and unrevealing.
TodE
I have not tried it yet but, "Kool Mat" was recommended to me for heat resistance. Lowered cockpit by 20 degrees! If money is no object why not Kool Mat then Dynamat? Kool mat folks are nice to talk to. They make precut kits for most British cars. Go to koolmat.com for information.
Good Luck!!
Tod
Keoke
:nonono:
Neverr tell management every thing you know! :wink:
J
jbmcohen
Member
Wow! Thanks for all of the replies; If I ever buy a log cabin, I'll be all set re: insulation. However, I was referring to my AH. I'll check into all (or most) of the suggestions. I also might try the carpet paint first, to see how it looks in a small area.
TimK
I was out driving in my Healey with its new Karvel Carpet, thick felt underlayment, and the Dynamat Extreme. I am convinced now more than ever that the biggest contributor to cockpit heat is hot air blowing through the cracks. Pay special attention to sealing the transmission tunnel to the cowl and to the floor. Don't glue it down, just make sure there is a tight seal all around. Also seal all the grommet holes in the fire wall, and of course get a good shift boot.
V heat shield Triumph Classifieds 7
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
tahoe healey Dynamat heat shield Austin Healey 8
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
R TR4/4A Tr4a, alternator heat shield Triumph 9
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
I How do I install Bugeye heat shield? Spridgets 4
Gliderman8 Heat Shield - will it solve my problem.... Triumph 15
I Bugeye heat shield color? Spridgets 11
Dudly Heat shield Triumph 0
19_again Carb heat shield MG 7
bigjones Vapor lock. Heat shield for fuel pump? Spridgets 5
M SU Carb Heat Shield Triumph 6
c5racer Gaskets with the heat shield? Spridgets 0
T Heat shield pictures- anyone have one handy? Triumph 3
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
19_again MGB MGB exhaust heat shield MG 3
Trick6 Tri Stromberg Heat Shield Coming This Spring/Summe Triumph 16
LastDeadLast Heat shield for HS8 carbs Triumph 3
tony barnhill MG Midget Heat Shield Spridgets 30
newmexTR3 TR2/3/3A TR3 Carburettor Heat Shield install Triumph 4
Steve P. '78 Midget carb heat shield? Spridgets 1
T Ratco Cable + Heat shield Triumph 30
6773 heat shield Spridgets 7
mjobrien Cockpit Floor Heat Shield Austin Healey 4
kyreb1862 MGB Heat Shield Color On A 77 MGB MG 1
Musicman Heat Shield Triumph 8
A SU H1 heat shield Spridgets 5
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
R Exhaust Heat Shield Austin Healey 3
