regularman
Filled up with 4.3 gallons and went 142 miles. That is around 33 mpg, a big change from 43 last time. That is what I get for doing a lot of hot rodding and trying to run 80 on the interstate, plus I had the carb off a couple times putting a spacer in between the carb and manifold (weber) and did several fuel pump tests and all this wasted some gas. Oh, well. I got mostly a full tank and no more driving until lake of the Ozarks. I will check it again there. If we go on some long drives and not in these mountains, I might be able to get a good highway mileage reading.
