this is the original battery box as I was drilling out the spot welds to remove it.
Pieces parts of the new battery box, copied from the original.
Box spot welded together no bottom yet.
bottom with dimpled drain hole. I got lucky to find a drawing in the service manual with the drain location since I did not have a bottom to copy.
bottom with drain. I did take a liberty and used a hose barb for the drain. The hose barb is still the correct diameter as the original drain tube. Once the bottom was spot welded in I ended up with a little oil canning so minor heat shrinking took care of that.
finished battery box ready to install. Tush was very helpful in letting me know about having to cut the fire wall to get the top flange under the scuttle. That will come down the road, for now it is out of the way. This was a fun project and looking back has helped me see that there are a lot of parts that have already been repaired and are ready to be added to the puzzle when the time comes.
The last photo is of the back with mounting brackets.
