So I'm in the process of putting everything back together on/in the doors. I have a couple of questions...
1. In regards to the bracket that mounts towards the bottom center of the door with 2 phillips head screws, has a piece of metal that spans the whole length of the door and has two ends that look like they hook on something, where do those ends go? Do they wrap around the rails so when the window comes down it keeps them from spreading?
2. I'm going to make the tool from Home Depot or Lowes to put the upper felt in, but did you guys put the glass in first and put it all the way at the bottom? I'm assuming so due to spacing but wanted to double check.
3. With the upper felt, is it better to do the inner or outer first?
Thanks!
Thanks!
