lesingepsycho
2 Problems
1st problem: The woodruff key in my 1275 crankshaft seems to be cocked. It has a big front to back taper that is stoping the crank sprocket from seating all the way back to the block. My question: Is the woodruff key removable? If so, how? I couldn't get it to budge and I figured the crankshaft was not a good place for "bigger hammer" tactics. :hammer:
2nd problem: The camshaft sprocket seemed to bind against the new cam retainer when I torqued it down. Is the cam sprocket supposed to bottom out against the camshaft? Is there supposed to be a spacer or something that I forgot? Or perhaps the new retainer's hole is just to small for the shoulder of the cam sprocket to pass through? If the hole in the retainer is too small should I enlarge the hole or narrow down the shoulder on the cam sprocket?
Thanks,
JACK
Thanks,
JACK
