Hello, I have a 78B with a 76 motor and radiator (no electric fans)
My wife bought the orig 76 in about 78 then about 81 rust brought on the switch to the 78 body, we have had this car nearly forever. I have not been driving the car much the last few yrs since my wife passed. But decided to start driving it more so that brings us to today, car runs great, webber, header, no smog stuff.
But with storing the car the water pump was leaking, replaced it last night cleaned the radiator ect.
So the temp sensor wire / sensor just under the t.stat in block, that wire has an additional wire in its "harness" (2 wires only) it is green, heaver gauge and has the black plastic protection sleeve on it that has a set that leads it back towards the coil, back of alternator?? wire has an insulated female spade connector on it and it is about a foot longer than the temp gauge wire.
Any Idea what this is to, I do not remember it as a "spare", it is not hot with ignition on or off, does not check to ground, car starts, gauges work, checking V at the batt looks to be charging when running.
My first thought is I knocked it loose when dropping the alternator to remove the water pump.
Anyone know where this wire should go, I appreciate your help. I would post a pic but new at the site and dont see a photo link for up load.
Regards
Regards
