help ID'ing e-type bits?
eschneider
Acquired these from a farmer who was cleaning out his barn and didn't want to throw them away. According to him, some bits are e-type jag, other bits are MGB..... I know nothing about e-types / xke's
jessebogan
Item number 1 part of the bonnet mounting Etype (broken)
2 Heater air inlet, from bonnet to heater box
Etype
3 Part of front suspension arm Etype
4 Headlamp chrome trim "crows foot" Etype
5 Ruined "amco bar: front of Etype
6 Heater pipe from bulkhead Etype
7 Possibly torsion bar? Etype (is it a heavy solid bar?)
8 Etype roadster trunk hinges
I would pitch #1 and #5, the rest might be worth something to someone.
So what do I win??
eschneider
eschneider
jessebogan said:
So what do I win??
You win your choice of #1 or #5.... <grin>
#6 seems more like an anti-sway bar...? it's heavy and solid.
#7 is some kind of torsion bar. It's heavy and splined.
#5 seemed more like some kind of bonnet reinforcement bit...?
Thanks for the help!
jessebogan
OK, rear sway bar it is. The Amco bar went between the bumper over- riders to protect the nose. They were a popular aftermarket accessory. There was another part of #3 that attached to the torsion bar that held the balljoint and so on. Only about 19,992 parts to go to get your own E type!!
Platinum
And would do MORE damage if hit than if they weren't there.
Don_Neff
Items #8 are the counter balance springs for the hood/bonnet. Gas struts weren't being used by Jag in those days.
jessebogan
ooops
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
